Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
550 Adams Grader UD-16 IH Motor
this thread has 40 replies and has been viewed 4372 times
Old 05-05-2017, 09:01:40 AM
King of Obsolete King of Obsolete is offline
Default Re: 550 Adams Grader UD-16 IH Motor
thansk for the update. i have not got started on the project due to it still being winter up here int he great "white" north.
thansk
KoO
Published Author
Old 05-09-2017, 06:49:27 AM
MotorMike MotorMike is offline
I hear that ! Let me know when you dig into that Adams, I will see what I can find down here for you. Never know...
The Following User Says Thank You to MotorMike For This Post:
Old 05-09-2017, 08:40:42 AM
ronm ronm is online now
The UD 16 is a 6-cyl. version of the UD/TD 9, so there should be some commonality of parts, I would think. Internal pieces like rods & pistons may interchange, although I don't have parts books to confirm that. Obviously head & pan gaskets won't be the same, but that shouldn't bother the King. . .
Smokstak member #442
Old 05-22-2017, 07:54:56 PM
You could try this guy here on Stak:
https://www.smokstak.com/forum/member.php?u=20494
He knows people who know people.
There is also:
http://www.hcea.net/page-1492157
Old 05-23-2017, 11:46:29 AM
You can also try the Roadbuilders and Heavy Construction Heritage Society of Canada
www.hchs.ca
Old 06-22-2017, 03:07:34 PM
halcon halcon is offline
Originally Posted by King of Obsolete View Post
in 2009 i aquired this 550 adams grader which the owner reported to the police that i stole it. 2 years in court and it became mine bt i lost interest in it because it was like a bad DIEvorce. now it is time to get working on this machine because i sure can use the wing to whip the snow over for wider trails in the bush.
where about do i get parts for the adams grader and will be looking for gaskets and maybe parts for the ud-16 IH motor.
thansk
KoO
Published Author
The UD16 is basicly a 9 series with 2 more cylinders tacked on. So that might help source a few parts. I ran Wabco graders when I was in the dirt business. The last dealer I dealt with was Vulcan equipment in Winnepeg MB
Old 06-22-2017, 10:47:35 PM
thansk guys, i have been working a little too hard and when the email from the BB arrived today i decided i better take time to work on the 550 adams.
i used the 922 cat loader to drag the 550 adams up to the shop so i could pop on a set of tires. the 3/4 impact had no troubles with the 1.5" socket headed bolts to get the wheels off. i then soaked a few things down with used oil so they will be easy to remove later on.
thansk
KoO
Published Author
Name:	550 adams grader june 22 2017 001.jpg
ID:	284977   Click image for larger version
Name:	550 adams grader june 22 2017 002.jpg
ID:	284978   Click image for larger version
Name:	550 adams grader june 22 2017 003.jpg
ID:	284979   Click image for larger version
Name:	550 adams grader june 22 2017 004.jpg
The Following 2 Users Say Thank You to King of Obsolete For This Post:
Old 06-22-2017, 11:34:26 PM
Had there been some particular part of the grader that had failed? Or do you know yet.
Old 06-22-2017, 11:47:52 PM
the grader was used to build a runaway at a remote lodge, then in 2009 we went and recovered it.
the motor had water down the exhaust so the heads will need repairs.
thansk
KoO
Published Author
The Following User Says Thank You to King of Obsolete For This Post:
The Following User Groaned at This Post:
Old 06-25-2017, 10:52:21 AM
it was a good day on friday night, i popped the heads off to find fresh water in #1 cylinder hole. this is because the tin can covering the exhaust rusted through with pin holes. oh well a little more work, lol.
thansk
KoO
Published Author
Name:	550 adams grader motor june 23 2017 027.jpg
ID:	285160   Click image for larger version
Name:	550 adams grader motor june 23 2017 028.jpg
ID:	285161   Click image for larger version
Name:	550 adams grader motor june 23 2017 029.jpg
ID:	285162   Click image for larger version
Name:	550 adams grader motor june 23 2017 031.jpg
Adams 201 Motor Grader Model 201 Weight? Rex Piekarczyk Vintage Construction Equipment 0 09-24-2015 01:23:59 PM
ADAMS Grader in KANSAS LandLFarm eBayŠ Auction Discussion 0 01-22-2014 04:34:00 PM
Adams Grader or another brand? LarryG Horse Drawn Equipment 1 02-26-2013 10:29:46 AM
Adams # 121 Pull Grader 5 and dime Farm + Industrial Antiques and Collectibles 1 01-24-2012 08:37:15 PM
Adams Road Grader bocephus_k6 Farm + Industrial Antiques and Collectibles 0 06-11-2009 04:54:35 PM
