Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
International D691
this thread has 2 replies and has been viewed 1298 times
Old 04-18-2017, 08:36:34 PM
stampmaint1 stampmaint1 is offline
Default International D691
Hi;
I am a new member. I have read Smokstak threads that I have come across, before. This is my current problem. I have a IH TD-20 200 series crawler tractor. The magneto went dead and it is hopefully getting fixed. In the mean time, I am trying to get the engine timed so I am ready for the mag when it comes. I have some information and photos that I will try to post. 3 photos did upload. I guess I will see if they go with this post. All new to me. My trouble is I see 2 different marks on the flywheel. I do not know which one to use. A big hello to my new friends here on smokstak.
ID:	280372   Click image for larger version
ID:	280373   Click image for larger version
Old 04-19-2017, 09:12:59 AM
Heins Heins is offline
Default Re: International D691
If the mag has an impulse, it should impulse at TDC or just past. The mark you show is TDC for cylinders #1 and #6. You have to have #1 on compression stroke and the mag timed to it. You can find #1 compression by having the engine switched to gas and spark plug out, and holding your thumb over the plug hole and turning the engine.
Old 04-19-2017, 09:27:00 AM
Thank you for responding. I made a whistle of sorts and put in number 1 cylinder spark plug. Turned the motor over till it started to whistle. I slowly jogged the engine over till these marks showed up. Must have been done before because of the yellow paint. I can see two marks. I don't know which one to use. thank you
International M David Appleton Antique Gas Engine Discussion 1 06-21-2014 06:35:33 AM
international LB Butch50 Antique Gas Engine Discussion 8 02-16-2013 04:46:20 PM
4 hp International Tom Sampson YouTube Old Iron Videos 2 07-18-2010 01:00:25 PM
International TD4 art7319 Antique Farm Tractors 3 07-15-2009 09:14:22 AM
International M 1 1/2 hp Jordan Antique Gas Engine Discussion 9 07-13-2007 01:04:50 AM
