Go Back   SmokStak > SmokStak® General Discussion > Antique Motorcycles
Antique Motorcycles All about finding and fixing old motorcycle engines and vintage bikes.
Antique Motorcycles
1968 Enfield clutch problems
this thread has 12 replies and has been viewed 985 times
Old 06-18-2017, 10:54:39 AM
TomBall TomBall is offline
Default Re: 1968 Enfield clutch problems
The owner was happy with the way it felt and took it home. The interesting thing I found out during my troubles is that the clutch basket floats on a boss and is not made to lock in position. The drive chain from the crankshaft goes around the sprocket on the basket so any sideways forces exerted by the drive chain could cause the basket to float when the clutch is disengaged causing inconsistent gap between the plates. This is just a theory of mine so don't take it as gospel truth.
Old 06-18-2017, 02:19:45 PM
Glad the owner is happy with it. Hope he keeps up on the maintenance.
As for the clutch float - sounds about right.
Old 06-18-2017, 09:57:09 PM
Glad you worked out the problems. I was going to suggest that you reffer to the originally specified oil.
Back about 79 a friend had a Kawasaki 1000LTD that I subsequently bought from him. It ran a wet clutch. Thinking to treat his bike right my friend tried using Valvoline racing oil in the crankcase. After the oil change the bike would not move! The clutch just sat and slipped.
To fix the problem we had to totally dissasemble the clutch and rinse each plate with gasoline. Put regular (Castrol 20W50) oil in bike and everything was fine again. Just something for others to keep in mind.
Doc
My sisters both got four brothers.... but I only got three!
Enfield Flat Twin 2 stroke skankingiant Small Air Cooled Gasoline Engines 8 07-03-2017 10:32:38 AM
Enfield Diesel single engine garyoldfriend Vintage Diesel and Oil Engines 0 12-05-2015 10:29:49 AM
1947 allis chalmers b clutch problems W3EK Antique Farm Tractors 5 05-25-2015 10:30:45 PM
1968 30ek T Blocher Onan Generators 2 03-29-2006 07:45:25 AM
help needed with enfield VSI mk1 ivan Antique Engine Archives 0 09-16-1999 06:50:43 AM
