Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
R G LeTourneau Rear Double Drum Power Control Unit
this thread has 12 replies and has been viewed 2048 times
Old 06-22-2017, 08:41:07 PM
halcon halcon is offline
Default R G LeTourneau Rear Double Drum Power Control Unit
Has anyone on here ever saw a model "B" rear double drum power control unit. Appears very early and is quite light and small
The Following User Says Thank You to halcon For This Post:
Old 06-24-2017, 10:49:32 AM
Default Re: R G LeTourneau RDDPCU
Did you check with Duncan Keeler?
The Following User Says Thank You to David Hoover For This Post:
Old 06-24-2017, 10:35:23 PM
Question Re: R G LeTourneau RDDPCU
Yes Dunc and I had a visit about it and we thought that it may have been the second style R G built. It doesn't have the Timken bearings in all the spots the later ones did. The cable drums are a little smaller and built lighter than the model T or the R or even the model N. It is mounted on an Aliss Chalmers model LO and is made for that application. The LeTourneau Ident plate shows serial number B 5-- L ?
Old 06-25-2017, 12:46:18 AM
I'll ask the guy here that may have something. Be worth sending a note to Letourneu university, they'll have the info for sure. http://www.letu.edu/_Other-Resources...u/history.htmlhttps://museum.letu.edu/collections
Old 06-25-2017, 11:02:19 PM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
Images: 4
As unusual as that cable power is, The LO is even more so. Not many survived with the engine in it's original form. You wouldn't have a picture of that tractor would you? I have 2 model L tractors and they are both hydraulic equipped. One has the pump on the front of the motor, the other has the pump down on the side of the trans case running off the counter shaft.
Old 06-28-2017, 09:18:00 AM
This one is only equipped with the cable control, the engine is original.
Old 06-28-2017, 01:58:15 PM
IIRC, the LO came with the Hesselman engine (oil-injected, sparkplug ignition, gas-engine level compression engine popular in Europe for awhile)...
Had a batch of little manuals on Wauki-Hesselman models, descibing the special high-tension mags and plugs; think they're all gone, but will check if anyone wants one...
The Following 2 Users Say Thank You to Bud Tierney For This Post:
Old 06-28-2017, 03:22:41 PM
I would sure like to have one if available. P M me what you need for one and I'll send it to you. This engine would be an Allis-Chalmers Hesselman , the linage goes back to the Stearns engines. But I suspect Hesselman specified the fuel and ignition system. So I'm sure it would be helpful.
Old 06-28-2017, 06:17:05 PM
FWurth's Avatar
One Millionth Post
Images: 4
The gas engine is almost the same except the heads and the injection pump as I recall. Most operators gave up on the Hessleman set up and converted them to simple gas operation. Pistons and sleeves and valve train are also the same as the Allis A or late E tractor. For some reason the gas tractor used 2 carbs on the single / common intake, one right and one left hand linkage. Bud, if you find a couple of those I'd be interested as well. I think the Monarch 75? was the predessor to this model. They used the big Leroi 4 cyl RAI in that version
Old 06-29-2017, 12:33:25 PM
Been downsizing for a couple years (off and on) so not sure what's left or where it/they might be; will check the logical places in the next day or two and advise.
MEP002A Control Unit Assmbly Mariner Onan Generators 3 12-28-2015 09:25:21 PM
Very Old Moisture Control Unit Information Needed Sherwood Farm + Industrial Antiques and Collectibles 1 07-27-2014 12:11:11 PM
MEP-903C control unit & connect harness mrhaugen Military MEP and Aircraft Gen-Sets 0 01-06-2012 03:51:24 PM
No voltage control old 30kw unit Alan Burger Onan Generators 16 01-05-2010 10:54:15 AM
Kohler 3A22 w/Cutler-Hammer Control Unit Manual(s) ? Ross Hunt Kohler Generators 3 06-10-2008 08:37:06 AM
