Vintage Construction Equipment Graders, Shovels, Fork lifts, Dozers & Crawlers, Pay loaders & Fork lifts
Buffalo Springfield Roller
this thread has 47 replies and has been viewed 3984 times
Old 02-17-2018, 05:34:57 PM
ihredo4 ihredo4 is offline
Default Re: Buffalo Springfield Roller
8228DE = PU-8 = U-6 & UD-6 Power Units,
= PU-17 = IU-6 & IUD-6 Tractor-Engine-Over-Axle-Unit,
= TC-23 = T-6 & TD-6 Crawler Tractor,
= TC-28 = Farmall M, MV, MD & MDV Tractors,
= TC-33 = O-6, OS-6, ODS-6, W-6 & WD-6 Tractors,
= TC-34 = I-6 & ID-6 Tractors.
The engine block should have a serial number hand stamped into a machined surface just below the head and behind the injection pump. Engine number would be stamped like this:
FDBKM######## = Farmall MD = TC-28,
FDBKVM######## = Farmall MDV = TC-28,
IDBKM######## = International ID-6 = TC-34,
IUDBKM######## = International IU-6 = PU-17,
OBKSM######## = McCormick ODS-6 = TC-33,
TDBKM######## = International TD-6 = TC-23,
UDBKM######## = International UD-6 = PU-8.
Hope this helps you out and if I can help anyone else just ask.
The Following 2 Users Say Thank You to ihredo4 For This Post:
Old 02-17-2018, 09:35:20 PM
sdarmstrong sdarmstrong is offline
I will check again for this number. Thanks .
The Following User Says Thank You to sdarmstrong For This Post:
  #33
Old 02-18-2018, 04:13:43 PM
So just to confirm , a manual for a u d 6 will suit my engine ? I didnít get to it today to check for the hand stamped serial no .
Also does anyone know the correct manual I should be looking for to suit the roller itself ?
Old 02-18-2018, 05:58:09 PM
John Newman, Jr.'s Avatar
ihredo4
Ref: Post #26
"...With the third valve in the head on each cylinder..."
I do not see a third valve in each cylinder. Remember this is a gas start - Diesel run engine. There will be a spark plug hole (probably the one on top) and the injector hole (probably the one on the bottom) along with the intake and exhaust valves for each cylinder.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 02-18-2018, 06:31:03 PM
The valves seats are in the head . I also have the valves and one of the spark plugs is in the head itself .
Old 02-18-2018, 11:37:18 PM
Originally Posted by John Newman, Jr. View Post
ihredo4
Ref: Post #26
The third valve opens to decrease cylinder pressure for starting on gas. The lever on the left side of a gas start diesel engines dash board not only decompresses the engine but opens a butterfly on the gas start system to allow the small carb on the right to feed the engine. It also opens the ground so the mag or distributor can be operational. I'm sure the lever does some other items as well be haven't looked at them in a few years.
---------- Post added at 09:37:18 PM ---------- Previous post was at 09:10:33 PM ----------
The serial number on the block should give you the answer to this question. All SHOULD be the same but you just never know.
The Following User Says Thank You to ihredo4 For This Post:
  #37
Old 02-19-2018, 09:37:22 AM
ronm ronm is offline
ihredo4
Ref: Post #26
There is no spark plug hole into the combustion chamber. The spark plug is in a separate chamber opened up by the starting valve, & closed off when running on diesel. The smaller hole in the pic below the 2 valves is the starting valve seat. Slanted hole on top is the injector.
Smokstak member #442
  #38
Old 02-19-2018, 01:00:54 PM
Finally got the engine no !
UDBKM3941
---------- Post added at 12:00:54 PM ---------- Previous post was at 11:58:56 AM ----------
So thatís an international UD 6
Yes ?
Old 02-20-2018, 05:45:20 AM
You got it my friend. Your best bet for a parts manual would be the PU-8. Currently one for auction at:
https://bid.beckortauctions.com/view...alog/id/17405/
page 2 item # 176 for $10-12
the B suffix merely represents the second revision of the PU-8 manual.
Old 02-20-2018, 06:32:27 AM
Hi
Is the Pu 8 the same as the ud 6?
Buffalo Springfield useful hints for Buffalo Pitts Roller Engineers TractorDom Steam Stationary Engines, Traction Engines, Steam Boats 1 11-23-2015 12:19:58 PM
Buffalo Springfield Steam Roller frogfoottrader Steam Stationary Engines, Traction Engines, Steam Boats 15 04-25-2013 11:43:47 AM
Buffalo Springfield roller Bill Hazzard Steam Stationary Engines, Traction Engines, Steam Boats 0 10-08-2012 09:57:30 AM
Buffalo-Springfield 5 ton Roller Peter Steam Stationary Engines, Traction Engines, Steam Boats 36 09-12-2008 04:41:23 PM
Buffalo-Springfield Roller Mike in NC Steam Stationary Engines, Traction Engines, Steam Boats 0 02-02-2005 12:17:03 AM
