PB Blaster?
this thread has 25 replies and has been viewed 1928 times
Old 03-09-2018, 04:34:28 PM
Sunnybrook Sunnybrook is offline
Default Re: PB Blaster?
I have never taken to PB Blaster.
I love kroil but I am too cheap to pay for it.
WD40 is wonderful to brighten old paint and brings out old lettering as Harry noted. I use alot of it.
The 50/50 ATF-acetone mix works well to loosen as well.
Old 03-09-2018, 09:47:23 PM
Motormowers's Avatar
I'll echo whats been said about Zep 45. I used to use it way back. So far back I forgot all about it. I used to buy a few cans from work. Its real good stuff and a close second to Kroil but Kroil deff is the best I've ever used. Like I mentioned before yes it is expensive but a little really does a lot. You dont have to drown the part like with other sprays so a can usually lasts me 6 months to a year, thats economical for me considering how much grief and wasted time and broken bolts it saves. WD-40 is perfect for that squeaky screen door thats it lol
Remove the all rotten apples out of your basket of life and toss them in the trash where they belong.
Old 03-09-2018, 10:44:36 PM
PB Blaster is pretty well my go-to for penetrating oil. However, if something's REALLY stuck the only thing that's gonna get it loose is the old heat and beat method-have yet to find a penetrating oil that ALWAYS will get stuff loose-not even Kroil!
Mike
Old 03-09-2018, 11:06:51 PM
Sonny Reese Sonny Reese is offline
I have used PB, but still need the BIG hot wrench to go with it!--I think the PB will get driven by the heat, and make it work better, just my .0000011/2! lol!!! thanks; sonny
The Following User Says Thank You to Sonny Reese For This Post:
  #25
Old 03-10-2018, 07:21:59 AM
Elden DuRand's Avatar
Images: 11
"Same idea with Permatex RTV Silicone. They deliberately make a weak spot in the cap so it will break and ruin the remaining contents of the tube."
Vanman:
I've got the same gripe. Also, the caps break on the small tubes of JB Weld.
Take care - Elden
http://www.eldensengines.com
Old 03-10-2018, 10:52:30 AM
DustyBar DustyBar is offline
Vanman:
I guess we should think ahead and just apply a band or sleeve on it ahead of time. It happens every time.
Sand Blaster bfmco7 Machine Shop and Tool Talk 29 02-15-2011 09:51:26 PM
recommended abrasive blaster? Tom Schaech Paint Shop 2 05-20-2002 07:29:57 PM
Cabinet blaster Jim Moody Antique Engine Archives 4 05-06-2001 09:04:19 AM
Sand Blaster advice Norm Antique Engine Archives 2 12-19-2000 05:36:37 PM
