Delco-Light 850 Restoration
this thread has 0 replies and has been viewed 1293 times
Old 01-22-2003, 02:27:36 PM
Bill Pladl
Default Delco-Light 850 Restoration
I am in the process of restoring a Delco-Light 850w light plant my Grandparents used to light their house in the NY Catskill area. The plant was in use, with the glass batteries, until the mid 60ís when a spring was lost from the ignition points leaving the unit inoperable. A replacement part was not available and the plant was abandoned.
The plant is in good shape with the exception of a few missing parts. The parts that are missing: Exhaust valve spring & retainer, brush springs, and the ignition points assembly. The exhaust valve was also missing but a local machine shop was able to set me up with a replacement. I suspect the original ignition coil is not working since a Ford coil and resistor were wired in next to it.
Any info is greatly appreciated.
Delco Light 8-C-3 help CS Brown Generators & Electric Motors General Discussion 1 06-09-2005 04:53:14 PM
delco light brian baker Antique Engine Archives 1 06-02-2004 11:20:19 PM
Delco Light Don Wiebe Delco and other Low Voltage DC Light Plants 0 06-12-2003 11:35:19 AM
Delco Light Don Wiebe Delco and other Low Voltage DC Light Plants 1 06-08-2003 01:24:33 PM
Delco Light Bill Garman Antique Engine Archives 0 01-17-2000 01:17:23 AM
