Wisconsin Engines
Zenith / Wisconsin Manual Scans!
this thread has 7 replies and has been viewed 22626 times
Old 10-02-2011, 11:48:01 AM
KD5BYB's Avatar
KD5BYB KD5BYB is offline
Images: 3
Default Zenith / Wisconsin Manual Scans!
Morning all,
Recently I bought a whole pile of Wisconsin-related Zenith Carburetor manuals off of that e-place for like $10.
Since I have a cold and feel like garbage, I scanned it all in this morning into PDF formatted files and uploaded to my webpage:
B-600-9 Application List by Wisconsin Engine Manual. A listing of Wisconsin Models and the Carbs used:
http://www.kd5byb.net/Wisconsin/Manu...by%20Model.pdf
Parts Usage List B600-9 Wisconsin Engine. A list of parts (repair kits, etc.) used on Wisconsin engines:
http://www.kd5byb.net/Wisconsin/Manu...0Wisconsin.pdf
Zenith 161 Carburetor Parts Listing. A diagram of the 161 series carb and the parts used:
http://www.kd5byb.net/Wisconsin/Manu...%20Listing.pdf
Zenith 61 and 161 Series Carbs, Operation and Service:
http://www.kd5byb.net/Wisconsin/Manu...%20Service.pdf
Zenith 61 Series Marine Carbs, Operation and Service:
ftp://kd5byb@ftp.kd5byb.net/Wisconsi...ne%20Carbs.pdf
Zenith 87 Series Carbs, Parts Plate and Parts List:
Zenith 87 Series Carbs, Operation and Service:
THIS is probably the best one of the bunch. Zenith Master Price List 1 AUG 1950. Lots of application info, parts info, and cross reference info:
http://www.kd5byb.net/Wisconsin/Manu...20Complete.pdf
Zenith Specification Bulletin date 7-15-1951. A listing of Wisconsin carbs, the Zenith number, and the parts used in that carb. Very neat:
Zenith Technical Bulletin T-47A. Economizer Calibration Drill Sizer for 161 and 67 series carbs:
http://www.kd5byb.net/Wisconsin/Manu...67%20Carbs.pdf
Zenith Technical Bulletin T-58, Drilling Bushings for Back Suction Economizer:
http://www.kd5byb.net/Wisconsin/Manu...Economizer.pdf
Zenith Technical Bulletin T59, Throttle Shaft Reamer for Rebushing Throttle Bodies. A nice guide to the tools needed for rebushing Zenith carbs:
http://www.kd5byb.net/Wisconsin/Manu...%20Reamers.pdf
Zenith Technical Bulletin T57, Throttle Shaft Bushing Installation Procedure. Shows how to rebush Zenith throttle bodies. Very interesting.
http://www.kd5byb.net/Wisconsin/Manu...stallation.pdf
Zenith Throttle Shaft Bushings and Tools. Shows what bushings and tools are used for various carb models.
http://www.kd5byb.net/Wisconsin/Manu...nd%20Tools.pdf
I hope these are of use to folks. Some of them I've seen before, but these scans may be of higher quality of a higher quality original.
Thanks much,
ben
---------- Post added at 10:48 AM ---------- Previous post was at 10:27 AM ----------
Couple more - these are magneto manuals, again specific to Wisconsin engines.
Wico XH-1 Magnetos. Original not in real great shape, and I think I've seen better copies elsewhere but why not feed it thru the scanner anyways?
http://www.kd5byb.net/Wisconsin/Manu...20Magnetos.pdf
Fairbanks Morse XH-1 Magnetos:
http://www.kd5byb.net/Wisconsin/Manu...No%202921A.pdf
Enjoy!
-ben
The Following 7 Users Say Thank You to KD5BYB For This Post:
Old 10-03-2011, 09:09:13 AM
KD5BYB's Avatar
Images: 3
Default Re: Zenith / Wisconsin Manual Scans!
Couple more.
Included in the pile was an ADH AE AEH AEHS manual. That is nothing new, except I've never seen a scanned copy of the distributors section. Kind of interesting to see who sold parts way back when. Interestingly, the one here in Huntsville, AL, Farm Tractor, is still here except Farmer's Tractor became Tri Green Equipment:
http://www.kd5byb.net/Wisconsin/Manu...%20Section.pdf
One of the online ADH AE AEH AEHS manuals is missing a page from the parts listing. So here is a scan of the manual I have limited to the parts listing section:
http://www.kd5byb.net/Wisconsin/Manu...rts%20List.pdf
thanks much,
ben
The Following User Says Thank You to KD5BYB For This Post:
Old 10-10-2011, 08:18:20 PM
mikebramel mikebramel is offline
Thank you.
Old 10-10-2011, 08:20:11 PM
KD5BYB's Avatar
Images: 3
No problem! Glad I can give something back to those that have helped me so much here.
thanks,
ben
Old 01-13-2012, 11:26:09 AM
KD5BYB's Avatar
Images: 3
Here's two more:
One for a TH/THD and one for an AEN:
TH/THD:
http://www.kd5byb.net/Wisconsin/Manu...D%20Manual.pdf
AEN:
http://www.kd5byb.net/Wisconsin/Manu...N%20Manual.pdf
Thanks much,
ben
Old 02-01-2012, 09:05:08 PM
vetnske vetnske is offline
is there any way you can direct me to some one who may have a magneto flywheel for my ahh? Ted M 732-757-7521 Thanks
Old 09-14-2013, 09:06:25 AM
FSmyth FSmyth is offline
Tell the moderator to give you a thanks!!!
Old 09-13-2016, 09:06:45 PM
crazy4bolens crazy4bolens is offline
Much needed!! Thank you.
Wisconsin/ Zenith carb troubles Horse Power at 511 Wisconsin Engines 15 10-12-2014 09:16:24 AM
Wisconsin AENL Zenith carb kit mshane Wisconsin Engines 6 11-06-2012 07:12:58 PM
Wisconsin AKN manual Felon Wisconsin Engines 12 05-18-2012 07:30:47 AM
Manual for Binks 33-1171 Portable Air Compressor scans Phil Paint Shop 1 03-12-2010 09:07:22 AM
Wisconsin manual bouncingbennyboy Wisconsin Engines 3 07-26-2009 10:42:14 PM
