Continental recoil parts
this thread has 9 replies and has been viewed 762 times
Old 01-09-2017, 05:09:45 PM
TomBall TomBall is offline
Default Continental recoil parts
Can anyone help with parts locations for a recoil starter for a Continental AU8B single cylinder engine. I need them for a restoration of an old small tractor?
Old 01-09-2017, 10:42:14 PM
s100 s100 is offline
Default Re: Continental recoil parts
Tom Ball,
You're going to have to do a bit better information wise. Maybe post a picture of what you have. To the best of my knowledge Continental did not make any recoils of their own, but when so equipped used purchased parts. I have seen these with Schnacke recoils but that's not to say there aren't others, or that some previous owner didn't adapt one himself.
I expect someone with more knowledge will help, but myself all I can suggest is everyone's most well-hated online auction site. I think there are some suppliers that deal exclusively in these old Continentals too. But once again I don't know of any.
Good luck!
Old 01-10-2017, 01:42:40 PM
Here are some pictures of what I'm working on. All the guts are missing from the recoil. Note the nut that holds the flywheel on. That is the part the recoil must engage by my way of thinking.
ID:	272052   Click image for larger version
ID:	272053   Click image for larger version
ID:	272054   Click image for larger version
Old 01-10-2017, 10:56:55 PM
Yup, That's a Schnacke. I'm not sure what that is all about with the teeth on the end of the flywheel nut, though. The Schnackes I am familiar with engage onto the hex and do not have those teeth. As to parts, I suspect you will have to find someone who has one sitting in their junk box. I have a similar Schnacke on a K90 Kohler generator engine. That set is apart as I search for parts. If I can find the starter and if you wish I can take a picture of the flywheel side of the thing, at least.
Old 01-11-2017, 07:47:28 AM
Thanks for the info. I would like to see the pics if you get time. Yesterday, I adapted a Tecumseh starter and cup. I had to space the cup out from the flywheel with washers but it worked and I got it running. I would still put it back original if I find the parts. If not, I will probably machine a solid spacer and leave it as it is now.
Old 01-11-2017, 04:43:30 PM
gdstew gdstew is offline
I have several of those notched nuts, they were used with a matching piece that was chucked up into a drill. I have NOS 4 or 5 different thread sizes, they have been in the back isle for 50 years!
Old 01-11-2017, 06:11:00 PM
What purpose did the notched nut serve when the recoil was bolted on? Was it one of those deals where if the recoil fails you can pull it off and still start the engine, similar to the starter cups having a notch in the outer edge to wind a rope around ? I would think you would need a large drill to turn that baby over.
Old 01-11-2017, 11:37:25 PM
Butch Yowell's Avatar
Butch Yowell Butch Yowell is offline
That nut fit the sprocket on the recoil on Davy Bradley cont. engine they use.
Butch Yowell
Old 01-12-2017, 11:46:54 AM
Shawsplace56 Shawsplace56 is offline
That is the military Version of the beloved Schnacke recoil and you do find them on ebay generally they had a cable not a rope hole claw its called but also called a Schnacke
Old 01-13-2017, 07:11:22 AM
You are right about the cable instead of the rope. This one has a cable. I haven't seen the machine it came off yet. I'm told it is some sort of a small tractor that was used to push shopping carts at an old grocery store, possibly an adaptation of a military machine. I'll try and get a picture of it.
Onan 5.0 KQ-3P/1A needs Recoil Parts gunteach Onan Generators 7 04-16-2014 08:03:33 AM
Continental parts oldyeller67 Antique Gas Engine Discussion 0 11-05-2012 05:08:13 PM
continental y69 parts needed coyote62ny Multi-Cylinder Stationary Engines and Power Units 3 04-20-2012 02:01:38 AM
Continental AU 7 need parts jabone Small Air Cooled Gasoline Engines 1 07-01-2011 11:19:47 AM
HELP! Need parts for Continental AU8 luteman123 Garden Tractors / Mowers / Scooters 5 07-15-2010 08:07:02 PM
