Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Jacking up a Forklift?
this thread has 70 replies and has been viewed 13721 times
Old 02-01-2013, 02:53:14 PM
Power Power is offline
Default Re: Jacking up a Forklift?
If the brushes are worn, you can try whacking the starter. May be able to get a few starts that way. Get it off slope onto something level and real solid.
Old 02-01-2013, 03:48:28 PM
OTTO-Sawyer's Avatar
I can't believe I forgot to suggest that....
Even if you can't get at it to whack it with a hammer, if you can get good solid broom handle or a small steel bar fed down to it, being careful where you hit it and how hard, it should get it going at least one more time. Sometimes it helps to be holding the key in the start position While hitting the starter though if the springs aren't too weak or the brushes burnt too bad you might be able to jar it loose with a single 'whack' and then hit the key. If the brushes are badly burnt, you can beat the hell out of it and still not work.
If you can't get it started that way, at least try to drag it to a level spot to work on it.
Old 02-01-2013, 04:18:07 PM
I bought a 5 Ton H-F forklift jack years ago for mine. I've used it a few times with only 2 x 4's, 4 x 4's and 6 x 6's used to support it on both sides when lifted to height for tire and brake work. Never use cement/cinder blocks or those pressed steel auto ramps. Those things can suddenly "FAIL" and put a hurting on you, if your lucky. Worse things can happen if not so lucky, especially if no one is around to help, or dial 911 .
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-01-2013, 04:26:45 PM
len k len k is offline
Giving it a wack works for ~2 weeks on a chev , then it's dead. When we take them apart its usually the brushes worn 1/2 way thru the mounting screw. Sometimes also support bushings worn so rotor drags on stator , than's only ~.010 away.
Old 02-01-2013, 10:50:41 PM
tapkoote tapkoote is offline
All the jobs I worked on
any load bearing block wall was poured solid
with grout and rebar installed.
I'd find a place to buy used 12X12's,
then sell them back.
tap
Old 02-01-2013, 11:23:14 PM
Thanks guys, I'll have to watch for some big iron at the scrap yard next week, they will let me borrow stuff like that. The new lift is a 6000 Lb capacity Daewoo, propane so no more burning eyes inside the warehouse(you probably could have re-lit exhaust on the Clark), it has lights, brakes, and side shift(although I would have preferred power forks), and a back-up alarm(which I promptly disabled). Followed that google link to "jacking up a forklift" and found that tires on blocks is not recommended, and blocking the counterweight is not recommended either, yet considering where I need to get to on this lift those are my only 2 options for the rear end, I guess I'll just have to do both. Going in from above would require removing intake and exhaust manifolds, and at this point I do not even know what engine it is. Weight on this machine is 10,000 and change, it would squish a human head without trying. Pic 1 and 2 the machine, where its been parked since October (it died days before I left for Nevada). Pick 3 shows manifolds in the way. Pic 4, well the starter is somewhere way down there.
ID:	156762   Click image for larger version
ID:	156763   Click image for larger version
ID:	156764   Click image for larger version
Old 02-01-2013, 11:51:13 PM
One of the local scrapyards called me last year, they wanted me to sell a couple of skidsteer loaders and this forklift, I was halfway thru writing the ad on this machine when it occurred to me that maybe I could use it. Its not quite the machine the Clark was, but then when was the last time I needed to pick up 8000 Lbs inside the warehouse? Lift height was only 14ft, but the Clark had not gone to full extension since I moved to a warehouse with 14ft eve height either. So I sold the skidsteers and used my commission for the down-payment. Advertised the Clark at scrap value ($1000) hoping someone would keep it going, lots of people looked at her, but with no brakes, no power steering, a growling hydraulic pump, and the 3 handed monkey maneuvering required to start it, well nobody bit. A couple of the scrap haulers made offers, but I already had a solid offer from the yard and they would pick it up when they dropped off the Daewoo. I hated to do it, but after 60 days it was clear the Clarks only value was as scrap, and I needed to finalize the deal. So after 23 years of usage I drove the Clark out of the warehouse one last time, only had to re-start it 5 times to get it up by the road, then I pulled the gauge panel and added it to the decoration on my tool box, the most amazing thing is after all the years it was parked outdoors no one ever smashed her gauges. Visiting the scrap yard for the next 2 weeks was tough, oh the horrible things they did to my machine, yeah, stupid as it may seem I cried about it, heck I'm crying now just writing this.
ID:	156767   Click image for larger version
The Following 2 Users Say Thank You to dalmatiangirl61 For This Post:
  #28
Old 02-02-2013, 01:07:06 AM
with ya girl
it's sort of like thinking about scrapping the ford wrench my dad had.
Couldn't do it.
The Following User Says Thank You to tapkoote For This Post:
  #29
Old 02-02-2013, 02:31:52 PM
10,000 pounds .....WOW not what I expected by looking at it, but I have no experience on lifts, just cars and small trucks.
Counter weight bolts probably only hold it's weight, likely not big enough to hold weight of whole vehical. On cars/trucks I like to suport the frame itself, not sure if you can get at it from picture. I suppose you could look for manual on web , it must have some factory recomended lifing points.
  #30
Old 02-02-2013, 03:18:17 PM
I tried an Internet search and couldn't find anything in the first few pages, but I did come up with a website you might want to check out and ask your question there.
http://www.forkliftanswers.com/
I typed in a quick search on that site myself, and there currently aren't any answers on changing a Daewoo starter under the search function, but when that page came up it did have another box for typing in and submitting your question.
I didn't go so far as to actually ask the question How to replace starter on a Daewoo, because I didn't know what model you had or any other specifics on it, but it looks like a good place to check out for that and any other future problems when you have the time.
Forklift Question Greg Shipley Lifting and Loading 19 10-15-2017 10:43:35 PM
Old Towmotor Forklift Fred Prichard Lifting and Loading 13 12-26-2014 02:30:56 PM
CAT Forklift 501P Miehle48 Lifting and Loading 1 06-25-2012 10:10:02 PM
Forklift Not Included DaveTexas Antique Gas Engine Discussion 5 03-02-2011 12:37:22 PM
