Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
this thread has 368 replies and has been viewed 80977 times
Old 11-14-2016, 04:09:22 PM
kracked1 kracked1 is offline
Default Re: Antique Steel Wheeled Mechanical Plows...History, Weed Finds, Prices, Parts, Etc.
Here is a JD plow my buddy stumbled onto. Any idea of the model? I cant find anything that has that style attachment from frame to beam. Also what looks like a clamp style tail wheel.
The Following User Says Thank You to kracked1 For This Post:
Old 11-15-2016, 10:01:07 PM
lukeste lukeste is offline
Images: 1
It's a john deere model 55 diamond back plow
The Following User Says Thank You to lukeste For This Post:
  #323
Old 11-16-2016, 09:37:08 AM
Thanks much. Never heard of a diamond back. Are they kind of rare?
Old 11-16-2016, 12:23:35 PM
Images: 1
Yes. They are. And it's a cast knuckle. Probably early 40's vintage.
Old 11-16-2016, 03:54:21 PM
Thanks much for the info.
  #326
Old 11-16-2016, 07:49:33 PM
Bryan Donaldson Bryan Donaldson is offline
Can I ask what makes it a "diamondback" plow, and what the specific features would be to identify it positively?
I have one that looks very similar to the one in post 321 (at least to me), but I'm not knowledgeable at identifying specific models of plow. Ours is 3-16, with steel wheels (see pictures). Whatever it is, it plows well.
Name:	Case L JD 3 bottom 9 2014.jpg
ID:	268192   Click image for larger version
Name:	JD 3 bottom McD 15-30.jpg
The Following 2 Users Say Thank You to Bryan Donaldson For This Post:
  #327
Old 11-16-2016, 09:00:43 PM
Bryan that is the same plow, just on steel.
  #328
Old 11-17-2016, 09:47:12 PM
Images: 1
The back stabilizing beam is set up as a diamond configuration. Later they set it down flat. The truss for each plow standard has a cast knuckle... Later ones went to gusseted plates and did away with the casted ones. I suppose cheaper and stronger. The cast ones do occasionally break if you have rocky ground.
The Following 4 Users Say Thank You to lukeste For This Post:
  #329
Old 12-08-2016, 02:48:30 PM
Doing some scanning for an article and came across this - 1918. A number of companies made these. It would be fun to see one in action. My Ideal tractor hauled one, though probably not a P&O, in breaking work.
The Following 6 Users Say Thank You to G Willikers For This Post:
  #330
Old 12-08-2016, 04:06:53 PM
Dan thomas Dan thomas is offline
Mr G
If I remember right there was one on the Bloomgren auction a few years back maybe someone else knows where it went.
The Following 2 Users Say Thank You to Dan thomas For This Post:
  #331
Old 12-08-2016, 04:25:56 PM
Russ Hamm's Avatar
Images: 1
Warms my heart to see that 22-36 out doin a job of plowing.
---------- Post added at 04:25:56 PM ---------- Previous post was at 04:24:38 PM ----------
Correction.........15-30.
The Following 2 Users Say Thank You to Russ Hamm For This Post:
  #332
Old 01-04-2017, 08:54:23 PM
Hello all,
A friend of mine scored this disc plow and does not know what kind it is.
I am not real well versed in disc plows and have not seen it in person. Looks to be a JD, but not positive so I told him I would post it here where all the well educated Smokstakkers could take a look and help us out.
Thanks in advance for being such a great resource for everyone in need.
"WE ARE THE NETWORK"!
Tony
ID:	271755   Click image for larger version
ID:	271756   Click image for larger version
ID:	271757   Click image for larger version
The Following 4 Users Say Thank You to Tony Thompson For This Post:
  #333
Old 01-07-2017, 02:16:51 PM
Brothers Clemens's Avatar
Tony in 1962 there was in Holland already and farmer that buld an plow robot.
You do not have to sit on the tractor anymore and you can go to your bed and let the robot do the work.
It is not steeled wheels but it is very intresting to watch,
Keep posting your wonderful threads,
Chris,
https://www.youtube.com/watch?v=-AoGZ87YIW0
The Following 4 Users Say Thank You to Brothers Clemens For This Post:
  #334
Old 01-07-2017, 03:05:04 PM
In about 1937 there was a radio-servo controlled Farmall F-30. It was described in Gray's Tractor Development book.
The Following User Says Thank You to Oilpulled For This Post:
  #335
Old 01-08-2017, 12:05:21 PM
Please see post #332.
I am looking for help to Identify a mystery disc plow for a friend.
Can any of our educated members help us out?
Thanks for all the great posts from everyone
Tony
The Following User Says Thank You to Tony Thompson For This Post:
  #336
Old 01-08-2017, 03:15:10 PM
Demoman Demoman is offline
Tony - I will look through mine and see if I have one like it. My guess is emerson.
Old 01-10-2017, 02:00:23 PM
DanHansen DanHansen is offline
Hello to all. This is new to me so be kind. Thanks Tony for the post of pictures in post #332. I found this plow in a old farmers fence line and it took a better part of 6 months to convince him to sell it. This past weekend i scratched around on it and found some ih markings and cast numbers starting with PO. Any literature i have come across does not match up to ih disk plows. If you look at the rear adjust crank it faces toward the operator and all ih i have found face the rear of plow. On the back casting is a name but have not been able to make it out. I will try to post pictures but it is my first time so be patient. Thanks.
Photo 1 is disc part #. Photo 2 is rear casting. Photo 3 is a symbol on a casting. Photo 4 is casting on clutch lift.
ID:	272056   Click image for larger version
ID:	272057   Click image for larger version
ID:	272058   Click image for larger version
The Following 3 Users Say Thank You to DanHansen For This Post:
  #338
Old 01-11-2017, 04:59:34 AM
53 Super M 53 Super M is offline
Got a picture of the whole plow?Might be an IH harrow plow.
Old 01-11-2017, 10:10:19 AM
Yes in post #332 of this thread are 4 pictures of the plow. Thanks Dan
Old 01-11-2017, 05:07:07 PM
K Cooke K Cooke is offline
That IHC PO plow is the same model as was given free with a Titan or 8-16 in the late stages of the tractor war with Ford . Its a single digit number maybe 5 Pictured in post 317
Old steel wheeled tractor in a movie model k rumely Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 54 12-30-2016 04:41:01 PM
IHC steel wheeled wagon JHuggans Farm + Industrial Antiques and Collectibles 0 01-19-2013 08:09:04 PM
Another Steel Wheeled H Nebraska Cowman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 08-12-2012 06:05:17 PM
Steel Wheeled Farmall H daleed Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-09-2011 08:01:41 PM
Steel wheeled wagon JIMnWV Horse Drawn Equipment 2 09-30-2010 08:09:00 PM
