Wisconsin Engines
Wisconsin Interchangeable HS 8D Info
this thread has 13 replies and has been viewed 1590 times
Old 08-09-2015, 08:54:28 AM
drbish drbish is offline
Default Wisconsin Interchangeable HS 8D Info
Picked this up,had to have it but cant find any info on it.What were they used on,I need a parts list.I did a search on the Wisconsin site and was made in 1966
The Following 2 Users Say Thank You to drbish For This Post:
Old 08-09-2015, 09:02:15 AM
Default Re: Wisconsin Interchangeable HS 8D Info
Some more pictures
ID:	231569   Click image for larger version
ID:	231570   Click image for larger version
Old 08-09-2015, 09:21:27 AM
Zira Zira is offline
Some info here:
http://www.wiengines.com/support_repair_spec/13
Many parts will be the same as the regular S8. I think I have a paper manual around here some where, if you are not in a hurry I can probably scan it.
Not a common engine.
The Following 2 Users Say Thank You to Zira For This Post:
Old 08-09-2015, 09:29:21 AM
K-Tron K-Tron is offline
You do not see vertical shaft Wisconsin engines everyday. I have only seen one HBKN, never the HACN or the HAENL. Its good to know there are HS8's out there too! Please restore her to its former glory!
Chris
The Following User Says Thank You to K-Tron For This Post:
Old 08-10-2015, 08:03:01 AM
edward moller edward moller is offline
that was originally used on a lawnmower, i have a parts breakdown & manual for that engine. very rare engine
Old 08-10-2015, 08:46:18 AM
Bolens 1000 Bolens 1000 is offline
If anyone has the parts/repair manual please post it!
I'm curious to see the internal parts breakdown.
Never got to see one of these up close or inside before!
Old 08-11-2015, 07:46:53 AM
Bruce Dorsi Bruce Dorsi is offline
Originally Posted by drbish View Post
What were they used on?
The hub on the crankshaft appears to be for a Snapper riding mower. ...The die-cast drive plate would screw onto this hub. ....The blade-drive pulley would be driven by the two flats on this hub.
Snapper made a 41" cut rider in their early years, but I don't know if a Wisconsin engine was installed on them at the factory.
The Following User Says Thank You to Bruce Dorsi For This Post:
Old 08-11-2015, 12:55:29 PM
gdstew gdstew is offline
Snapper used a 1" x 3 5/32" straight crankshaft engine. I don't remember them ever using a Wisconsin cast iron engine. I think the engine in question was used by Bolens but I am not sure. Our family was a Snapper distributor from 1957-1985 and a Snapper dealer until 2 years ago.
---------- Post added at 12:55 PM ---------- Previous post was at 12:37 PM ----------
And yes, that looks like a Snapper hub.
The Following 2 Users Say Thank You to gdstew For This Post:
Old 08-11-2015, 06:31:33 PM
HS8D Wisconsin was not used by Bolens.
Old 08-12-2015, 12:15:17 AM
I found a reference to that engine being used by Bunton, same as the HS-7D.
Chris
The Following 2 Users Say Thank You to K-Tron For This Post:
Are IHC LA 1 1/2 - 2 1/2 Side Plate's Interchangeable ? Claremont Antique Gas Antique Gas Engine Discussion 0 03-07-2014 08:43:42 AM
Solenoids interchangeable? MBB Onan Generators 10 03-18-2011 09:41:22 PM
Albin 0-2 & 0-21: parts interchangeable?? DennisT Antique Marine Engines and Outboard Motors 0 03-01-2011 11:55:38 AM
Are 3 hp IHC M sleeves interchangeable Brian.P Antique Gas Engine Discussion 1 09-25-2010 09:59:59 PM
Are the cam gears interchangeable? bbuchorn Onan Generators 4 02-20-2009 01:35:41 PM
