Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
Piston Rings - Dura-bar
this thread has 9 replies and has been viewed 1949 times
Old 11-06-2015, 06:23:28 PM
Wayne Riedlinger Wayne Riedlinger is offline
Default Piston Rings - Dura-bar
I want to make piston rings for an old engine I am working on, a 6 cylinder Pontiac. after talking to several machine shops I was told about a product called Dura-bar. It comes in several different grades. It was suggested I use the 65-45-1 which is a ductile cast iron. I was also looking at a Gray G2 product Has anyone have experience with this stuff. I have quite a bit of material we made rings for a Rumley years ago but it is far too big and I just had it poured in a foundry.I know I can buy rings from several places but I am looking at the option of making them myself.
Old 11-06-2015, 06:32:01 PM
Wayne A Thackery's Avatar
Wayne A Thackery Wayne A Thackery is offline
Default Re: piston rings.-Dura-
Wayne,
I have used old cylinder liners to make pistons rings out of with great success! Just a thought...
Wayne A Thackery
Keizer, Oregon 97303
The Following 2 Users Say Thank You to Wayne A Thackery For This Post:
Old 11-06-2015, 06:52:26 PM
Thank you Wayne, its good to have options.
Old 11-06-2015, 10:16:43 PM
Ironsides Ironsides is offline
Wayne,I seen an old club member make them out of good quality cast iron pipe I had a doctors appointment so couldn't stay to see how he done it---perhaps you could Google it and see if anything comes up,good luck Norm
Old 10-29-2016, 07:26:14 PM
Harvey L. Harvey L. is offline
I need rings for 25 hp Reid. Can you help?
Harvey Sorensen
hms793@hotmail.com
The Following User Says Thank You to Harvey L. For This Post:
Old 10-30-2016, 11:13:28 AM
What size are the rings you need?.
Old 10-30-2016, 02:37:20 PM
Harry's Avatar
Images: 312
Our sponsor: http://www.ringspacers.com/
-- Harry Engines Videos Photos
The Following User Says Thank You to Harry For This Post:
Old 10-30-2016, 11:43:13 PM
I'll pull the piston out and get back to you. I believe they are 9.5 inch.
Harvey
Old 11-06-2016, 07:51:48 AM
Good sized rings. I think your best bet would be as Harry said -ringspacres .com. to make rings that big would take a bettor lathe then my Chinese 12 inch.
Old 11-06-2016, 09:58:50 AM
Default Re: Piston Rings - Dura-bar
There are many many steps in making rings that work. One of the most critical is the heat treatment of the blanks then the sizing operation heat process that is crucial. I'd forego the headaches and just buy them from Otto. Why make them three times when you can just pick up the phone.
Using Rubber O rings for piston rings Roger U Scale Model Engineering 18 09-26-2011 06:55:35 PM
Piston Rings Oldsiron Antique Gas Engine Discussion 5 07-07-2010 09:26:07 PM
Are less piston rings better? Rod Fielder Antique Gas Engine Discussion 6 05-08-2010 11:58:16 PM
Piston Rings ROBERT K Antique Gas Engine Discussion 10 03-06-2010 01:03:43 PM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Antique Gas Engine Discussion 3 06-24-2007 01:50:53 AM
