A quick question on Delco fuel system...
this thread has 9 replies and has been viewed 1430 times
Old 11-09-2015, 12:14:34 PM
Default A quick question on Delco fuel system...
I'm making steady progress on my Delco Light 850. Yesterday I removed the fuel tank for the usual inside de-rusting and discovered that the fuel pick up tube....a piece of 1/4" copper....has no check valve which surprised me. Instead, the end of the tube is cut at an angle. Is this the normal factory set up?
There is a port on top of the mixer for priming but it appears that the pick up tube relies strictly on the engine rpm to provide enough suction when starting.
Old 11-11-2015, 08:13:58 PM
Dale Burkman Dale Burkman is offline
Default Re: A quick question on Delco fuel system....
The 850's don't use a check valve. The angle cut is the factory end. Dale Burkman
Old 11-12-2015, 07:14:53 AM
Thanks Dale.......I suspected as much. Even though the gas only has to be "pulled" up a few inches I really expected some sort of check valve as on my other engines, even a little ball check. I just wasn't sure!
Old 01-16-2016, 08:21:30 PM
pbruxer pbruxer is offline
I have a bunch of Delcos and all have a check ball at the fuel pickup. These low compression engines will not start without fuel at the mixer immediately. 850 models run on kerosene and the priming cup is for a little gasoline to get them running up to speed.
Old 01-16-2016, 08:27:59 PM
Good point. The low compression (and it IS low) probably won't create much suction and maybe a much longer start up time. I have some used 8 volt golf cart batteries lined up and, although I'm sure they'll work fine, I really should keep the cranking time to a minimum.
I'll try priming with gas and see if it will run long enough to pull fuel up the line. Adding a check valve would be easy if needed though, in fact I've been giving it some serious thought lately just to keep the cranking time shorter.
Old 01-16-2016, 08:31:49 PM
Junkologist's Avatar
Images: 160
My Delco doesn't have a check valve. I choke it and it starts right up with no problem. You shouldn't need one and if you add one, it's just something that could cause problems after sitting. If it ain't broke , don't fix it.
Mike
SmokStak member #146
Old 01-16-2016, 08:33:00 PM
Makes me wonder if the check valve was for the Canadian market?? I'll try it without first and see what happens. Thanks guys!
Old 11-21-2016, 12:10:58 AM
Slimfinnish Slimfinnish is offline
Will it hurt the engine to run on gas. Slimfinnish
Old 11-21-2016, 11:35:36 AM
No, it will not hurt the engine to run on gas. The compression is lower than most gas engines so that it will run on kerosene, but it will run just fine.
As an update to this original post, I replaced the entire fuel line with a new one, having a loop in it. This keeps some gas right at the mixer and makes it start a bit quicker. I removed the check valve as I think it was actually starving the engine for fuel a tiny bit.
The Following User Says Thank You to George Andreasen For This Post:
Old 11-22-2016, 01:50:44 PM
abowman89 abowman89 is offline
I honestly didn't realize they were kerosene engines.......
1st post, 1st engine, question- fuel system Kurly Antique Gas Engine Discussion 4 09-28-2011 09:38:51 AM
What is everyone using for fuel line quick-connects? Nazrat Onan Generators 3 08-29-2011 08:37:16 AM
Delco (generating system) ulysses5 Generators & Electric Motors General Discussion 0 09-05-2008 08:44:27 AM
Quick fix for a leaky fuel pump SethM Antique Gas Engine Discussion 6 07-10-2007 12:46:33 AM
Fuel System Question Steve Dawkins Generators & Electric Motors General Discussion 27 01-05-2007 01:44:27 PM
