Hanomag AR38 with D52 Engine
this thread has 18 replies and has been viewed 3803 times
Old 11-27-2015, 06:44:46 PM
retrofit88 retrofit88 is offline
Photo Hanomag AR38 with D52 Engine
We are amid language barriers and out of stock parts in the restoration of this Hanomag tractor. With Benoit Christiaen's help, we found Theopold Tractor Parts because Hans Heinrich Munk does not have the glow plugs. Unfortunately, there is no picture on the website for the glow plug we believe we need. Here is a picture of the tractor and the glow plugs. The "replacement" plug is BERU stamped 6 volt; TYP 171 (which is it's kilowatt rating.) We checked out their parts catalogs and found nothing that would appear to fit. The thread is 1" x 14 thread pitch.
Staged Photo inside is from Dragone Auctioneers website. Doesn't she look pretty?
We hope some Stakker out there has the connection to help us get the restoration of this beautiful machine back on track.
Name:	Hanomag Thread Diameter.jpg
ID:	239825   Click image for larger version
Name:	Hanomag Thread Pitch 14.jpg
ID:	239826   Click image for larger version
Name:	Hannah outside.jpg
ID:	239830   Click image for larger version
Name:	Hanomag Tractor_Staged by Dragone Auctioneers.jpg
The Following 7 Users Say Thank You to retrofit88 For This Post:
Old 11-28-2015, 06:37:36 PM
Gede20 Gede20 is offline
Default Re: Hanomag AR38 with D52 Engine
Hello Retrofitt88,
The glowplugs you are looking for are Beru 171W
Every now and than they pop op on ebay for sale but they are rare and only used for these engines and where only made by hanomag and beru.
The Following 2 Users Say Thank You to Gede20 For This Post:
Old 11-29-2015, 02:15:25 AM
Norm Johnston Norm Johnston is offline
With a 1 inch thread you have the option of making a threaded bush and use a modern glow plug, of which there is many options available, I have a 2 cylinder Deutz tractor that I did this to and it works perfectly. You only have to find the right voltage and reach.
The Following User Says Thank You to Norm Johnston For This Post:
Old 11-29-2015, 01:22:12 PM
Brecht Brecht is offline
Hi Retrofit88,
You can find 3 of them on Ebay in Germany.
http://www.ebay.de/itm/Beru-Bosch-Gl...AAAOSwMTZWROZQ
The Following 2 Users Say Thank You to Brecht For This Post:
Old 11-29-2015, 03:15:09 PM
with this one you would have four:
http://www.ebay.de/itm/Beru-Gluhkerz...IAAOSwEeFVMoPB
Old 12-01-2015, 09:17:23 AM
This is a great suggestion. Thank you all so much for your help.
Old 12-04-2015, 06:34:03 PM
Its a great very original tractor, very hard to find in this condition. Most of these tractors where converted into rubber tires. It also still has the double battery tray, one for the 6 volt battery for the glowing system ( the beru 171w's are 6 volt) and a 12 volt battery for starting. That would mean you have a 12 volt generator with a risistor for the 6 volt battery.
For the glowplugs you could also use Bosch 0 250 002 004 or KE/GA2/4 These are the original replacement for the beru 171w and easier to find. The old glowplugs are easy to modify to make the new ones fit
The Following User Says Thank You to Gede20 For This Post:
Old 01-03-2016, 05:15:48 PM
Joaquim Joaquim is offline
Hello and good evening, my name is Joaquim Deu and be Girona (Cataluña) SPAIN.
Congratulations on the tractor Hanomag AR38, very original and hard to find.
I have tractor Hanomag RD 36 del año 1931 I am now restoring.
My tractor bring the horse in front, I'm looking for information and I find horse.
Anyone know the history of horse ?
---------- Post added at 04:15 PM ---------- Previous post was at 04:04 PM ----------
Here send some photos of the tractor.
The Following 2 Users Say Thank You to Joaquim For This Post:
Old 01-24-2016, 03:01:56 PM
GTfan GTfan is offline
Hello Joaquim,
your pictures are not visible.
The horse is the heraldic animal of the city of Hannover, where the Hanomags were build.
I think you mean this horse in front of the radiator:
http://pictures.tractorfan.nl/groot/...nd-hanomag.jpg
The horse was only on the first rd36, yours from 1931 is from the first production year.
My AGR38 has a later front plate.
Try to contact theopold-parts:
info(et)theopold-parts.de
replace the (ed) in the line above with an @.
Theopold knows the pre-war Hanomags very well, sells many parts and might find a way for you to get the horse back.
kind regards,
Fabian
Old 12-01-2016, 11:21:36 AM
Question Re: Hanomag AR38 with D52 Engine
Originally Posted by GTfan View Post
Hello Joaquim,
kind regards,
Fabian
Dear Fabian,
I found the glow plugs two different times, so now we have ONE spare glow plug. The Hanomag glow plugs had a porcelain washer. The BERU 171W that came out of the Hanomag does not. We don't know if it ever ran with the BERU 171W plug intact. We were able to get the wiring diagram for another tractor that has two six volt batteries. We are looking for a resistor to make sure we don't kill the new glow plugs. We were wondering if you can take close up pictures of your tractor from the other side. Also, if anyone out there has insight about wiring this tractor, we'll appreciate any guidance you are able to provide.
Do you know the brand Hanomag? hanomag driver Antique Farm Tractors 26 12-03-2015 07:18:20 PM
HANOMAG WD Grosspflug running again Gede20 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 10-06-2013 04:55:12 PM
