Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
New to Me Clark C500-30
this thread has 3 replies and has been viewed 1180 times
Old 03-12-2016, 09:56:16 PM
Ed ke6bnl Ed ke6bnl is offline
Default New to Me Clark C500-30
just brought home and unloaded my clark C500-30 forklift. got it running, brakes are ok and the hydraulics are ok. BUT it is an automatic that when you get moving it is like a stick shift car taking off in 4th gear. slow and not much power till it gets going. There seems to be a lever of some sort missing at seat level to the right of the drivers seat, below the seat is a rod that seems to go to this missing lever and it goes to the transmission and would like to know what it does and how it works. Seems like a 60 ish year. flathead motor.
And I would like to know what fluid goes in the gear drive for the hydraulic pump. Thanks for all your help.
Old 03-13-2016, 10:03:26 PM
MoRo's Avatar
MoRo MoRo is offline
Default Re: New to Me Clark C500-30
The missing lever may be a hi-lo for the trans. Might be in hi range, hence the slow startoff.
Monte Rodacker
Wastewater Maintenance Operator III
Old 03-31-2016, 12:09:47 AM
IronworkerFXR IronworkerFXR is offline
Images: 49
Hi and lo on mine is left side of steering column below the forward reverse shuttle shift .
Old 05-11-2016, 08:28:55 PM
NH2112 NH2112 is offline
Is there a parking brake lever somewhere? I have no idea of the model number because the data plate is missing, but our shop forklift is a late 70s/early 80s 5000lb cushion tire Clark and the park brake lever is to the right of the seat. Pointing forward is released.
Clark MD-6 SMBryanSr Vintage Diesel and Oil Engines 5 08-27-2013 03:54:57 PM
Clark 40 hp Jack Innes Oil Field Engines 4 07-02-2013 06:33:57 AM
Clark 40 hp oil? Jack Innes Oil Field Engines 3 05-14-2013 08:12:14 PM
Clark 40 hp Jack Innes Oil Field Engines 1 04-12-2013 05:10:01 PM
Ed Clark of Clark's Trading Post Passes David Steam Stationary Engines, Traction Engines, Steam Boats 2 10-04-2009 09:58:09 PM
