Float Repair
this thread has 17 replies and has been viewed 1445 times
Old 06-28-2016, 08:03:20 PM
J Ware J Ware is offline
Default Float Repair
Took my Twin City 21 32 to Natl. Thrashers last weekend, it ran great. Got home and went to unload it and couldn't get it started, and gas was running out of air cleaner. Took carb apart and found float logged with gas. Was able to get the halves of the float apart.
Has anyone had any experience with soldering a float. I have to fix this as these carbs or parts are like hens teeth.
Or maybe you know of someone that custom makes new brass floats. Jim
Old 06-28-2016, 08:17:33 PM
JoeCB JoeCB is offline
Default Re: Float repair
what does the float look like? dimensions ? repop brass floats are available for things like Model A Fords and likely other applications as well
Joe B
The Following User Says Thank You to JoeCB For This Post:
Old 06-28-2016, 09:30:47 PM
Its round with a 2 inch o.d. and is 1inch thick. I could solder the float arm on a new float , just need to find a replacement. Jim
Old 06-28-2016, 11:01:30 PM
Gene Williams Gene Williams is offline
Dave Reed- ringspacers.com has some floats made from some new composite material and it works well and is easy to shape to your needs.
I am sure some of the other sponsors have these as well
The Following User Says Thank You to Gene Williams For This Post:
Old 06-28-2016, 11:11:28 PM
clnr94 clnr94 is offline
I have took floats to the TV repair shop over the years an had them re soldered because they can do it without putting so much solder on it an making it too heavy
The Following User Says Thank You to clnr94 For This Post:
Old 06-29-2016, 12:43:03 AM
Amax Amax is offline
Default Re: Float Repair
I agree that you should be able to solder it yourself. Use good technique to clean, remove the old solder, reclean, and gentle heat to sweat in new solder.
The Following User Says Thank You to Amax For This Post:
Old 06-29-2016, 05:46:36 AM
Elden DuRand's Avatar
Images: 11
The way I've always fixed brass floats that leaked was to first, find and mark the leak.
Then, before re-soldering the leak, I punch a small hole in the float with an awl and drain the gasoline out of it. This might take some time or you could use the soldering iron to heat the float and force the gas out.
After the float is empty, fix the leak then use a little solder to cover the pinhole you made to drain it.
No real reason to take the float apart but that works, too.
Take care - Elden
http://www.eldensengines.com
Old 06-29-2016, 10:10:55 AM
Andrew Mackey Andrew Mackey is online now
I use either a Weller soldering gun at low heat or a hobbiest soldering pen used to solder lead glass window solder joints. 50-50 solder or 60-40, lead-tin alloys only. You need to clean off ALL gas residue and make sure both metal surfaces are clean. Rosin core electrical grade solder will work if not overheated, but I like acid core better. I have also used NO Krode plumbers solder paste too, with good results. As others have said, the trick is not to overheat! Only solder about 1/4" of the seam at a time, and let col 5 minutes between sessions. if you have already taken the float apart, the pin hole trick will be needed to prevent float collapse during cool down. You want the MINIMUM amount of heat to melt the solder!. Wipe off excess solder while the joint is still hot, then let cool thoroughly before continuing. A good carb repair shop should be able to hok you up with a new float. The new phenolic floats work well too, and you don't have to worry about the crap E-10 eating up the metal either.
Old 06-29-2016, 01:19:47 PM
On getting the gas out of a leaking float---don't think that if the hole was big enough to let liquid gas in, heating the float will evaporate the gas and the vapor will easily escape thru the leak...
Don't ask how I learned this...
The Following User Says Thank You to Bud Tierney For This Post:
Old 06-29-2016, 02:11:21 PM
carbking carbking is offline
One of the articles from my website:
BRASS FLOATS
Many mechanics have been conditioned to ask for a float each time they rebuild a carburetor, due to the reasonable price of modern, mass-produced floats, and the propensity of nitrophyl (foam) floats to absorb gasoline after time. In dealing with older, NON-CURRENT-PRODUCTION brass floats, neither of the above are true, and a mechanic should attempt to 'save' the float if at all possible.
The first step is to clean the float and inspect it for obvious damage. Small dings and dents are quite common, even in unused floats, and occurred when the manufacturer shipped the floats in bulk. Major dents (generally caused by water freezing in the carburetor) are not generally repairable. If one can hear liquid sloshing around inside the float, skip to the next paragraph. If the float looks to be reasonably damage-free, it should be tested. Testing is accomplished by grasping the float arm with a pair of needle-nose pliers, and submerging the float in very hot water. The hot water will pressurize the air inside the float, and a leaky float will blow a stream of bubbles.
If the float should need repair, it is important to understand how the float was originally produced. Virtually all brass float pontoons (the floating part) are composed of two pieces (a few are more) of brass soldered together. The pieces differ in the seam area, as one piece has a male seam and the other a female seam. One float piece will also have a small hole for temperature equilization. This hole will be covered by a small drop of solder, and will be as far from the seam as possible. The manufacturer would solder the two pieces together, allow the float to cool completely, AND THEN close the equilization hole. Soldering MUST be done using a soldering 'iron'. Repair should not be attempted using either a torch, or a soldering gun. If you plan on disregarding this advice, also plan on trying to find another float! The following procedure works for us (no, we will not repair your float unless we restore the entire carburetor): First, if liquid is present inside the float, find the hole, and remove the liquid by placing the hole down inside the hot water. The pressure will force the liquid from the float. If the float has much liquid, it may be necessary to remove the float from the hot water, allow the float to cool, and repeat the hot water dip. Once the liquid has been removed, and the leak has been marked, open the equilization hole by removing the solder. Solder the leak closed using as little solder as possible. A small piece of tape over the equilization hole will allow the hot water test to be preformed. If there are no leaks, remove the tape, and ALLOW THE FLOAT TO COOL COMPLETELY before closing the equilization hole. A final test, and you have 'saved' a valuable float.
Jon.
The Following 5 Users Say Thank You to carbking For This Post:
Old 06-29-2016, 09:51:48 PM
I just checked... Model A Ford Zenith carb float measures 2 - 1/8 dia X 1 -1/4 high. Brass (made in the USA) repop from Snyder's $16.25
Joe B
Old 07-04-2016, 08:25:28 PM
I would like to thank everyone for their help and input. I spoke with the carb king, his advice will be used with great respect and hopefully good results, I'm just not a fan of his prices or business practices. Jim
Old 07-04-2016, 09:33:20 PM
oldtractors's Avatar
Images: 5
Stick the float under hot water. The air in the float will expand and you will see bubbles from the pinhole. Then just turn the float so the pinhole is on the bottom and the heat will force the gas out. It may take more than one try to get all of the gas out. Put a small drop of solder over the pinhole and you are done.
Jim Evans
Old 01-05-2017, 11:45:58 PM
DustyBar DustyBar is offline
Originally Posted by carbking View Post
...ALLOW THE FLOAT TO COOL COMPLETELY before closing the equilization hole...
Here is a tip I just read about in a 1927 issue of Popular Science. To solder up the final hole, place the float in water so just the hole is above the water surface. The water will act as a heat sink and keep the rest of the float and air inside it cool, so that it doesn't build up pressure and prevent closing the final hole.
Old 01-08-2017, 05:46:52 PM
Dusty - my method is to hold the float in the fingers of my left hand while soldering with my right. If I burn my fingers, I didn't have enough heat in the soldering iron.
And while your tip is a good one (albeit somewhat difficult to ballast the float in the water), I have never had an issue using the method above.
Jon.
Old 01-08-2017, 07:41:10 PM
I wonder if they were using torch heated soldering coppers in 1927? They might be bigger and harder to control the heat.
Old 01-08-2017, 08:31:43 PM
This is what I still use. The more heat available, the better it works, as the less time is spent with the iron on the float. Roughly 1/2 second is about right.
Jon.
Old 01-11-2017, 04:57:23 PM
The old copper soldering irons came in many sizes - from about 1/4' in diameter to over 2" and 4" long! My grandfather used to solder copper gutters, and had a 10 piece set of irons, and a small iron propane furnace to heat them up. Quite a trick to heat an iron, then run up a ladder and solder a joint in place. I should know - I did it on a huge mansion in Tuxedo Park NY, for a roofer friend, many years ago. It took almost 2 weeks to do the gutters and downspouts. The home had slate roof, and a gypsy roofer broke many slates and ripped the gutters off the home before dis-appearing. My friend had to replace all the slate, and asked me to do the gutterwork. Man was that copper expensive!
Float material Jack Innes Carburetors, Mixers, Fuel Pumps and fuel delivery 4 11-07-2014 02:15:12 PM
Onan MCCK 6500 brass carb float repair and sizes sdowney717 Onan Generators 22 05-24-2012 09:26:34 AM
RFD Float wegotallama Steam Stationary Engines, Traction Engines, Steam Boats 7 01-01-2009 09:56:47 PM
makin' a float cgbusch Antique Engine Archives 3 09-25-2004 03:11:36 AM
cork float larry harding Antique Engine Archives 3 07-28-2004 08:30:17 PM
