Stearns Light Plant
this thread has 24 replies and has been viewed 2541 times
Old 07-02-2016, 08:16:23 AM
Noyes Noyes is offline
Default Stearns Light Plant
Looking for info on Stearns light plant made in Ludington MI. I have viewed info posted by Gus and it was very helpful. Thanks in advance A. Noyes
The Following 4 Users Say Thank You to Noyes For This Post:
Old 07-02-2016, 08:30:43 AM
Big Bird Big Bird is offline
Default Re: Stearns light plant
Rusty and dusty ... Just how I like it!!!!
Can you post some more pictures?
The Following User Says Thank You to Big Bird For This Post:
Old 07-03-2016, 08:03:43 AM
More pictures.
ID:	257466   Click image for larger version
ID:	257467   Click image for larger version
The Following 2 Users Say Thank You to Noyes For This Post:
Old 07-03-2016, 08:15:13 AM
Picture of building light plant was rescued from. This was a cider mill building from the 1880s. The light plant set in this building since 1938 when residential electric came to this area.
ID:	257470   Click image for larger version
ID:	257471   Click image for larger version
ID:	257472   Click image for larger version
The Following 5 Users Say Thank You to Noyes For This Post:
Old 10-16-2016, 07:52:09 PM
Default Stearns light plant
Started a new project. Restoring a Stearns light plant. If anyone has info on Sterns or American Bosch mags model # BA1ED19 I would be glad to here from you. See Pictures attached. Thanks A. Noyes
ID:	265555   Click image for larger version
ID:	265556   Click image for larger version
ID:	265557   Click image for larger version
The Following User Says Thank You to Noyes For This Post:
Old 11-27-2016, 08:36:43 PM
Light plant repainted, and running. Hope to display this next summer. Any other Stearns owners out there? Unable to post pictures to forum must be trouble with connection. Will try again tomorrow.
Old 11-28-2016, 09:40:40 PM
Default Re: Stearns Light Plant
Here are some pictures of the finished project.
ID:	269055   Click image for larger version
The Following 3 Users Say Thank You to Noyes For This Post:
Old 11-28-2016, 09:52:52 PM
Tim B's Avatar
Tim B Tim B is offline
Real nice job there. Any videos of it running? Do you have other lightplants? Thanks for sharing.
The Following User Says Thank You to Tim B For This Post:
Old 11-29-2016, 08:37:05 AM
Wow......gorgeous! A beautiful restoration of a rare plant...kinda puts my Delco Light to shame.......
The Following User Says Thank You to George Andreasen For This Post:
Old 11-29-2016, 09:45:50 PM
Trying to post a video. This is my first attempt, I will try to do a better job in the future. Some specs. on the light plant 3" bore 3" stroke, ball bearing mains insert rod bearings with shims on rod cap. RPM to generate 32 Volts unknown. 110 volt ac bulb in video it is illumated but not too bright as expected. Batteries 2- 12V and 1 6 Volt connected in series 30 volts DC. I welcome any advice on 32 Volt systems I am not an expert but would like to learn more. Most of my education has been from this site and other internet information. Thanks for sharing we may need this old technology in the future.
---------- Post added at 08:45:50 PM ---------- Previous post was at 08:36:43 PM ----------
Trouble loading video will try again tomorrow.
Stearns Light Plant Horse Power at 511 Generators & Electric Motors General Discussion 6 11-06-2011 11:17:00 AM
Info on Stearns lighting plant Robbo Generators & Electric Motors General Discussion 6 05-04-2010 08:50:54 PM
Info Needed Stearns Power Plant Josh Downard Generators & Electric Motors General Discussion 0 04-25-2004 04:10:24 PM
FM light 32 vlt light plant Bill Generators & Electric Motors General Discussion 6 02-19-2004 01:28:16 PM
