Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Blacksmithing and Metallurgy
Blacksmithing and Metallurgy Hand-wrought manufacture of metal objects, extracting metals from their ores, or purifying metals and casting useful items from the metals.
I need help identifying this anvil please
this thread has 13 replies and has been viewed 1360 times
Old 08-28-2016, 09:52:17 AM
kludgemechanic kludgemechanic is offline
Default I need help identifying this anvil please
Please let me know if you know what kind of anvil this is.
It looks to me like it is marked BB&CO on the front. The bottom of the anvil has an hourglass shaped depression. On the front bottom left it looks like a Z 123 and on the front bottom right it looks like A23812
ID:	261435   Click image for larger version
ID:	261436   Click image for larger version
ID:	261437   Click image for larger version
The Following User Says Thank You to kludgemechanic For This Post:
Old 08-28-2016, 09:54:07 AM
Default Re: I need help identifying this anvil please
Here are some more photos
ID:	261439   Click image for larger version
ID:	261440   Click image for larger version
ID:	261441   Click image for larger version
Old 08-28-2016, 09:55:10 AM
And one more for a size reference.
Old 08-28-2016, 10:46:10 AM
Gasenginegangster Gasenginegangster is offline
Thumbs up Re: I need help identifying this anvil please
Sorry I can't help you. That is a great looking anvil. Thanks for sharing with us.
Al
Old 09-03-2016, 11:11:27 AM
David Hughes David Hughes is offline
Suggest you go to anvilfire.com and ask the same questions. Alternately, arrange an interlibrary loan at your local library for "Anvils in America" by Richard Postman.
In brief, your anvil is painted (never a good sign, often paint hides problems), appears to be a forged anvil (wrought iron or mild steel body, steel working face forge welded to the body), from the lines it suggests a 20th century manufacture, made in USA, not marked in the hundredweight system which also suggests 20th century manufacture. Anvils are not antiques until you get into the pre-1800s manufacture, they are a tool and not a reference plate. Do not grind the surface (belt sanding OK), that can ruin an anvil (ruin the surface plate) and, like I said, they are not a reference plate, they are for beating iron. With big hammers. Embrace the pits, and a slight bow in the surface actually helps when straightening iron. From the size, looks like 100-150 lbs (weigh it on your bathroom scale).
If I was to guess, looks like a 1920s-1930s(?) farm or small shop anvil, possibly part of a farm blacksmithing kit as sold by Sears&Robuck, Monkey Wards, etc
Old 11-16-2016, 12:26:26 PM
Nessy Nessy is offline
It looks like a Trenton Anvil. The diamond imprint is a signature of theirs.
Old 11-16-2016, 04:06:37 PM
Bob Willman Bob Willman is offline
The Bostwick & Braun Company in Toledo, Ohio was a large hardware supply house. They may have had anvils with their name on them.
Bob
WB8NQW
Old 01-10-2017, 09:45:09 PM
Thanks for the help guys. I ended up building a 12x16 metal roof lean-to on the side of my shed. I cleaned most of the paint off the anvil, buried a large chunk wood in the ground and mounted the anvil to it. I built an overly large hood over the forge and piped up the champion 400 blower to it. I have only made 1 thing so far but plan on teaching myself the trade. It is a lot of fun.
ID:	272082   Click image for larger version
ID:	272083   Click image for larger version
ID:	272084   Click image for larger version
Old 01-10-2017, 09:46:17 PM
Here are more photos.
ID:	272086   Click image for larger version
ID:	272087   Click image for larger version
ID:	272088   Click image for larger version
Old 01-10-2017, 09:48:09 PM
more photos
ID:	272090   Click image for larger version
ID:	272091   Click image for larger version
ID:	272092   Click image for larger version
Old 01-10-2017, 09:49:56 PM
more photos. One of these shows the anvil on the log before I stripped the paint and mounted it.
ID:	272094   Click image for larger version
ID:	272095   Click image for larger version
ID:	272096   Click image for larger version
Old 01-10-2017, 09:51:59 PM
This is the only thing that I have made so far. It is a twisted bottle opener made from a rail road spike. I got it too hot in the forge. I learned a lot and I think the next one will turn out a lot better. Anyone have any advise on what I should try to make next to learn some basic skills?
ID:	272098   Click image for larger version
Old 01-10-2017, 11:12:09 PM
Amax Amax is offline
Drill 5/8" holes with a spade bit and you can use railroad spikes to hold the anvil tight to the stump. Looks a lot more correct.
Old 01-10-2017, 11:19:58 PM
I plan on doing that. I have to find some more rail road spikes first. The lag bolts are temporary. Thanks
Anvil Case441 Machine Shop and Tool Talk 6 09-21-2014 07:54:23 PM
I need some help identifying an Anvil oldproff Blacksmithing and Metallurgy 3 11-08-2013 11:06:50 PM
Would You Hit This Anvil? Steve Page Blacksmithing and Metallurgy 8 02-07-2013 11:05:27 PM
100 lbs. Anvil With CEM on it Weaponologist Blacksmithing and Metallurgy 7 02-01-2012 04:09:05 PM
No Name anvil Brian.P Blacksmithing and Metallurgy 3 11-30-2011 04:49:16 PM
