Zenith Carburetor on Yale Fork lift
this thread has 2 replies and has been viewed 684 times
Old 10-01-2016, 03:21:01 PM
Paso One Paso One is offline
Default Zenith Carburetor on Yale Fork lift
I am working on a old Yale Fork lift with a 6 cyl Flat head engine.
Do you know who supplied the engines to Yale?
This engine has a Zenith 12912 Carb on it.
I ordered a carb kit from Mcdonald Carb and Ignition. Great service and a nice kit they supplied.
There is so many unknowns as there no is markings on the anything on the fork lift other than the carb tag. Engine has PT casting on head.
I removed what appears to be a propane block above the carb.
After cleaning the carb and installing the kit it starts and idles very nicely.
However when you go to accelerate the engine it just boogs down gasping for air.
Major hesitation but will return to idle just fine.
What modifications were typically done to the carb when running it on Propane?
Not sure if this was a add on propane kit or stock from the factory.
I plan to run it on gasoline only.
What changes do I need to make to this carb?
What may have been done if it was a add on kit?
ID:	264372   Click image for larger version
ID:	264373   Click image for larger version
ID:	264374   Click image for larger version
Old 10-09-2016, 05:51:07 PM
mmcdonald mmcdonald is offline
Banner Sponsor
Default Re: Zenith Carburetor on Yale Fork lift
Should be a Chrysler engine if original.
info@mcdonaldcarb.com
Old 11-05-2016, 12:02:14 AM
dkamp dkamp is offline
From the photos you posted, I cannot identify this very well, but it may not be a propane mixer you've shown... it could be a Velocity Governor... or part of a VG system anyway...
Onan CCK MS in a small fork lift Steveb05 Onan Generators 28 10-01-2016 04:03:02 AM
International Harvester 560 Fork Lift Oilpulled Antique Farm Tractors 6 05-25-2013 09:34:25 PM
Allis Chalmers FTB 30-24 PS Fork Lift Ryan Anderson Lifting and Loading 8 07-23-2012 11:03:14 AM
Tipping the fork lift operator Dave Rhoades Antique Gas Engine Discussion 5 01-09-2005 11:37:53 PM
