Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Vintage Construction Equipment > Lifting and Loading
Lifting and Loading Pay loaders, Fork lifts, tow motors, jacks and hoists.
Lifting and Loading
Confirm this is a Chrysler Flat head
this thread has 9 replies and has been viewed 1606 times
Old 10-04-2016, 06:25:52 PM
Paso One Paso One is offline
Default Confirm this is a Chrysler Flat head
This engine is in an Yale Fork lift of an unknown year or Model.
If you know the engine or the model please confirm
Thanks In advance
ID:	264594   Click image for larger version
Old 10-04-2016, 06:34:28 PM
Default Re: Confirm this is a Chrysler Flat head
I'm fairly certain it's a Chrysler based on the external oil pump and the angled distributor driven from it. Now as to which one... They produced many flathead 6's from 20x something, through 218, 231, 251 and up to 265 cubes. Search the block ID number to find out whatcha got. There are a lot of sources for parts but one you might want to ring up is Vintage Power Wagons in Iowa. *Once you know what it is.
Old 10-04-2016, 06:40:27 PM
Matt Montague Matt Montague is offline
There is a "Pad" on the left side of the block, just below the head that will tell you what model the engine is.
Old 10-04-2016, 06:58:36 PM
BHoward BHoward is offline
Looks like one . Bill H.
Old 10-04-2016, 07:01:03 PM
I had seen the pad and saw no markings. I just took some sand paper to the pad and you can just see a faint Y
Old 10-04-2016, 07:54:14 PM
Bob Krummel Bob Krummel is offline
How long is the cylinder head? 23 inches (218 or 230 cu. in.) or 25 inches (236, 251, 265 cu. in.).
The Following 2 Users Say Thank You to Bob Krummel For This Post:
Old 10-04-2016, 08:42:09 PM
d huling d huling is offline
My Yale has the 218 engine Is this one gas or propane
Old 10-04-2016, 08:45:41 PM
Amax Amax is offline
It is definitely a MoPar flathead.
Tip offs are the oil pump, road draft tube, thermostat housing, freeze plug locations and a few other things.
I suspect a Plymouth/Dodge. The Chrysler/DeSoto motors were similar but a couple of inches longer.
Oh, and the motor is probably 1950 or older based upon the thermostat housing and water pump.
Old 10-04-2016, 11:43:58 PM
Bob, thanks The head is 23 inches long. so it's 218 or 230 good start.
D huling, It appears that it was both gas and propane not sure if it was a add on kit or factory, It had a propane block above the Zenith carb. and in the grill it has a circle to hold the propane tank inside the grill area.
Old 01-15-2017, 08:45:45 PM
aloris aloris is offline
One more little note, the oil pump cover is the shape of the Chrysler emblem. M a
Hobart welder/generator Chrysler t118-502 flat head six engine fryer tuck Welding Shop 11 02-13-2011 12:09:16 AM
Looking for A Pierce Governor for a Chrysler Flat Head Six Roger Wagner Antique Farm Tractors 4 11-20-2010 10:12:18 PM
4 cyl. Flat head, who made it? Gray Fire Rescue Unidentified Engines 4 08-12-2010 02:29:32 PM
Flat head Continental Brian.P Antique Farm Tractors 11 11-11-2009 04:59:47 PM
flat head Wade Kimball Antique Engine Archives 4 06-01-2000 11:00:31 PM
