Please identify this Mixer
this thread has 4 replies and has been viewed 840 times
Old 10-04-2016, 06:34:39 PM
Paso One Paso One is offline
Default Please identify this Mixer
I found in my "inventory " this propane mixer.
I have no idea where it came from or what it belongs too.
It just so happens to have the same bolt pattern as my Zenith 12912 carb.
Propane engines are not my bag.
Do I just clean it up and hook up a propane Tank???
ID:	264596   Click image for larger version
Old 10-04-2016, 07:59:47 PM
Bob Krummel Bob Krummel is offline
Default Re: Please identify this Mixer
Might it be from your Chrysler forklift engine?
Old 10-04-2016, 08:26:01 PM
The Mixer was here before the Fork lift, it was in a box of an auction score.
The fork lift had a block above the Zenith Carb that looks like the propane was introduced above the Carb. ( see other thread for Picture)
It will defiantly fit the Chrysler engine.
Old 10-20-2016, 02:47:06 PM
Correction the "mixer" will NOT fit on the Chrysler engine, The bolt pattern is smaller.
The Chrysler engine ( 216) has a wider bore.
Old 11-05-2016, 12:07:23 AM
dkamp dkamp is offline
That IS a Zenith gaseous fuel carbeurator... I have one essentially identical to it, but have been unable to find any documentation on it... so I don't know what it was set up for. The diaphram may be for metering, or it may simply be a fuel cutoff.
If you'd like to run an engine on propane, I'd recommend simply getting a new combination of regulated fuel, and a new demand regulator and a suitable mixer... both which are supported with good documentation.
an Impco 100 series mixer, and a Garretson KN with 'high flow' option orfice would do the trick nicely.
Please help identify mixer on 6 hp Witte Flywheels Forever Antique Gas Engine Discussion 6 09-04-2011 12:33:46 PM
Odd old mixer-help identify John Davidson Antique Gas Engine Discussion 1 02-23-2010 08:33:32 PM
What's this Mixer off of? shanelc50 Antique Gas Engine Discussion 8 06-09-2009 10:01:09 PM
"Chicago Mixer" cement mixer - Help! jpasture Antique Gas Engine Discussion 2 07-23-2007 05:04:12 PM
Mixer? Ralph Leonard Antique Gas Engine Discussion 2 09-02-2005 02:30:08 PM
