Wisconsin Engines
Wisconsin: twin cylinder dimensions
this thread has 21 replies and has been viewed 1338 times
Old 10-24-2016, 05:35:28 PM
MrMike MrMike is offline
Default Wisconsin: twin cylinder dimensions
I have fallen deep in love with the sound of these twins idle. I would like to find one and retrofit into a garden tractor. Does anyone have rough dimensions of one- H, W, D. Nothing exact needed. Thanks in advance.
Old 10-24-2016, 05:56:34 PM
Default Re: Wisconsin: twin cylinder dimensions
Go online and look at the manuals for them. Every dimension you want is printed.
Old 10-24-2016, 07:04:38 PM
Hmm. I've looked through several 80+ page manuals and don't see dimensions listed.
Old 10-24-2016, 07:47:03 PM
Heins Heins is offline
The two bangers are about 20" tall, 16" wide, and 22" long (crankshaft).
Old 10-25-2016, 09:09:33 AM
A tad big to stuff into a Panzer T70
Old 10-25-2016, 10:32:20 AM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
There was a video on here a while back of one on the front of a older cub cadet. search and you might find it. may be gone by now, I do not know how long videos are kept.
Old 10-26-2016, 01:27:02 AM
Keith Kessler Keith Kessler is offline
Hi,
Had one in a Bolens tractor when I was a kid. Not stock for sure. We were roto-tilling Illinois clay and the stock 10hp Wisconsin was weak. Dad made a pulley for the back that fit the taper and had several v-belt grooves. Worked well for 20 years. You could start it easily by throwing the flywheel with the mag.
I'm with the OP. I like the sound of them chugging away.
The tractor is long gone. I grabbed the engine and it is sitting back in the shop. I'm older now. I have no idea how I lifted that thing! They are like two engines as there are 2 heads on mine.
Good luck on your conversion. It does make the tractor a bit heavy in the steering.
Enjoy,
Keith
Old 10-26-2016, 09:14:35 AM
Kris Golden Kris Golden is offline
I put a Wisconsin twin on a 1978 Sears garden tractor. Bolted right on but since it was wider than the factory Tecumseh I had to make a jack-shaft to get the drive belt back inside the frame.
Oh, and I also had to modify the hood just a little.
BTW, the dimensions are HEAVY long, by HEAVY wide, by HEAVY tall.
ID:	266544   Click image for larger version
Old 10-26-2016, 04:52:20 PM
Zira Zira is offline
Oh, and HEAVY too.
Old 12-13-2016, 07:57:20 PM
What is the diameter of the crankshaft output?
Wisconsin THD Twin Cylinder Engine Magneto Problem hawkfan Magnetos, Ignition Coils and Spark Plugs 2 09-15-2014 03:42:38 PM
Wisconsin 12HP Twin Cylinder w/magneto and generator Cmdangelo83 Wisconsin Engines 2 02-05-2013 07:32:59 AM
Wisconsin, unknown twin, weak spark on one cylinder Cheddarpecker Magnetos, Ignition Coils and Spark Plugs 9 01-05-2012 07:36:04 PM
Twin City 60-90 Dimensions and Measurements twotoots2 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 11-05-2011 12:40:26 PM
Two cylinder crankshaft dimensions? Eric M. Steam Stationary Engines, Traction Engines, Steam Boats 0 01-21-2010 03:44:41 PM
