Wisconsin Engines
Wisconsin: twin cylinder dimensions
this thread has 21 replies and has been viewed 1373 times
Old 12-13-2016, 09:17:14 PM
Phil P Phil P is offline
Default Re: Wisconsin: twin cylinder dimensions
Hi
See if this helps.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 12-15-2016, 07:28:43 AM
Early Iron Early Iron is offline
I took a 1959 economy garden tractor with a 9hp Wisconsin and put a Wisconsin twin tjd in its place. The frame rails were extended about 5 inches and I had the clutch pressure plate bored out to fit the larger crank. I also cut about an inch off the total crank length. The original economy flywheel housing bolted right up to the tjd. The engine sounds great, and if the mag is timed right it starts almost instantly. This one is electric start.
The tjd is the best sounding of them all imo, and is the highest hp of all the twins. The engine is in an older Wisconsin power unit enclosure, which really makes it look excellent.
If you buy one of these engines be sure and clean the oil pan and oil pump out as they can sometimes stick and fail.
Old 12-15-2016, 09:01:37 PM
MrMike MrMike is offline
Nice work Early Iron. I am thinking about doing the same in a narrow frame Cub. Do the TJD electric starts have a charging system?
Old 12-16-2016, 12:41:31 AM
They use a 25-30 amp under flywheel system, yes.
Old 12-18-2016, 12:26:05 PM
Early Iron, do you run a PTO with yours? I'd like to have a PTO just to keep whatever tractor I put this motor into useful. Would like to run a snow blower and mower deck. Would this PTO be something able to handle that chore?
Old 12-18-2016, 03:23:26 PM
Heins Heins is offline
That PTO would handle all the power the engine would put out.
Old 12-18-2016, 04:34:21 PM
I found this THD with this Rockford PTO. It's huge! Would be way to big for my tractor.
ID:	270519   Click image for larger version
Old 12-18-2016, 11:51:59 PM
An economy tractor has the belt grooves right behind the engine. They can provide power or you can make a pulley for the front of the engine
Old 12-19-2016, 11:40:55 PM
Nathan K. Nathan K. is offline
Just thought I would note that the THD, TFD have a different firing order and sound than the TJD engines!.
Nathan.
Old 12-20-2016, 08:06:07 AM
I'd like to hold out for a TJD....but for the price tag on this THD and PTO- it's hard to pass up! At the least it'll work to fab up the frame.
Wisconsin THD Twin Cylinder Engine Magneto Problem hawkfan Magnetos, Ignition Coils and Spark Plugs 2 09-15-2014 03:42:38 PM
Wisconsin 12HP Twin Cylinder w/magneto and generator Cmdangelo83 Wisconsin Engines 2 02-05-2013 07:32:59 AM
Wisconsin, unknown twin, weak spark on one cylinder Cheddarpecker Magnetos, Ignition Coils and Spark Plugs 9 01-05-2012 07:36:04 PM
Twin City 60-90 Dimensions and Measurements twotoots2 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 7 11-05-2011 12:40:26 PM
Two cylinder crankshaft dimensions? Eric M. Steam Stationary Engines, Traction Engines, Steam Boats 0 01-21-2010 03:44:41 PM
