Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Iron Sides 2 hole portable sheller project
this thread has 45 replies and has been viewed 3694 times
Old 11-01-2016, 09:40:47 AM
DieselAddicted DieselAddicted is offline
Default Iron Sides 2 hole portable sheller project
Purchased this sheller a year ago and once home I discovered it was not in the condition I had hoped for, lots of dry rot. It has found its way to the front of the line and I am going to put it in working condition while saving as much of the original as I can. I will ad dpictures as I move along. The goal is to pull it out of the shop in the spring ready to shell corn. Shop is a bit crowded and hard to get decent over all pictures. The project gave me a reason to purchase a 15" planer and 8" jointer so all is not on the downside I have the cob and shelled corn elevators for it also.
The Following 5 Users Say Thank You to DieselAddicted For This Post:
Old 11-01-2016, 09:41:57 AM
Default Re: Iron Sides 2 hole portable sheller project
Few spots that will be repaired
Some of the rot That needs repaired.
Old 11-01-2016, 12:25:42 PM
Jebaroni's Avatar
Jebaroni Jebaroni is online now
Regardless, it's not often that people get the opportunity to nab up one of these machines. Very nice indeed! Wish it was mine!
Old 11-28-2016, 11:13:50 AM
OK on to the rebuild. Had a slight delay as I installed a dust collector system in the shop.
Hard to get pictures of the extent of the wood damages, Suffice it to say that if it were a wee bit worse this would be a total re-wood job. I THINK I can save most of it that is not structural but time will tell. Besides being left out in the weather at some point in its life it also has been attacked by powder post beetles.
The "frame" of the sheller is basically a square box made up of 3x3 stock of unknown species. This is one of the lower main beams that also holds the shelled corn chute. That chute is a casting, AMAZING foundry work.
The old beam showing the damage better and the new one made from white oak fresh out of the planer. The white oak was sawed on my farm about 8 years ago.
Since I am not going to completely disassemble the sheller the new beam only has a tenon on one end and I will have to trim it so as to get it in the mortise in the upright. The other end will be attached by driving a loose "tenon" through the hole in the upright and into a recess in the beam.
The Following 6 Users Say Thank You to DieselAddicted For This Post:
Old 11-29-2016, 05:35:41 PM
Paul Searl's Avatar
Paul Searl Paul Searl is offline
we have a Eureka as well, in much the same condition. I look forward to seeing how this goes, I hope we someday get ours running as well. I have a little bit of literature as well.
ID:	269125   Click image for larger version
The Following 3 Users Say Thank You to Paul Searl For This Post:
Old 11-30-2016, 12:06:38 PM
Paul, looking at the frame stenciling your sheller was sold by the same dealer as mine. I dont have the crib conveyor or drive set up and doesnt appear to ever had it. I noticed that yours does not have the right angle drive and pulley, neither does mine. Its a long shot at best but I would sure like to have the right angle drive parts some day.
Old 12-02-2016, 07:23:51 AM
This is the cross piece installed. The 45 degree brace to the left was not there originally but the upright to the left is in pretty poor shape right where that fan shaft bearing is attached. I would replace it except that is impossible without removing the sheller from the undercarriage and totally disassembling it The upright in structurally important as it not only holds the fan and it also holds the bottom of the feed elevator. Hard to explain but will become clear later,, I hope.
This piece fell off the sheller during transport. note the rotted tenons still in it. The cast iron pockets are for the legs that hold the feed elevator.
And the completed new part. We will need to be creative to attach it due to the lack of tenons and the integrity of the uprights.
The Following 3 Users Say Thank You to DieselAddicted For This Post:
Old 12-05-2016, 09:31:30 AM
Bottom frame work shelled corn chute completed. There is a lot of stress on the set of legs to the left due to how the feeder is mounted so I installed some extra supports. We will blend them in with chalk paint later in the hope that it looks like an old field expedient repair.
---------- Post added at 08:31:30 AM ---------- Previous post was at 08:24:16 AM ----------
The shelled corn elevator hangs on the right side and heavily stresses the entire machine to hold it in position. The heavy side of the sheller had settle down giving the entire sheller what Dad would have called the "dee-troit lean" I lifted it and drove builders shims under the mounts then tightened the through bolts. Pretty easy repair. The shims were cut flush, rubbed a bit of used oil on them and they are now pretty much invisible.
The Following 4 Users Say Thank You to DieselAddicted For This Post:
Old 12-05-2016, 09:47:50 AM
To the top and a couple relatively simple repairs. As you can see the top cover sides are in reasonable condition but the top is junk.
This is the shelled corn elevator mount and pivot with the old rotted wood all ready removed.
Repairs beginning on the top cover
And the completed repairs to the top cover and mount for the shelled corn elevator. This about completes the easy stuff next will be the ear elevator.
Old 12-06-2016, 11:24:53 AM
While I was up top measuring things I got the greasers all working. Luckily they are all almost full of the old type hard grease.
Surely this has been asked elsewhere but is there a source for that hard cup grease? I have an Appleton corn shredder to go through after this sheller and it has a 5 gallon bucket full,,, well almost ,,, of cup greasers on it.
When I was a kid we had one machine on the farm that had grease cups and dad had and old ESSO tin of cup grease and I remember him saying you couldn't get it any more,,,, 50 years ago.
IH Two Hole Sheller Project Tim Colwell Farm + Industrial Antiques and Collectibles 10 03-23-2017 08:33:16 PM
Two Hole Sheller with Bagger Scott Hartz Farm + Industrial Antiques and Collectibles 5 10-19-2016 08:26:07 AM
4-hole Corn Sheller Chuck H Farm + Industrial Antiques and Collectibles 1 08-07-2011 07:37:39 AM
8 hole Sandwich Sheller Dave Thompson Farm + Industrial Antiques and Collectibles 5 07-16-2009 10:24:48 PM
2 hole Sandwich Sheller Bob Ronning Antique Engine Archives 0 11-12-2004 08:16:35 PM
