Delco piston rings?
this thread has 5 replies and has been viewed 731 times
Old 12-03-2016, 03:16:41 PM
abowman89 abowman89 is offline
Default Delco piston rings?
So I heard a rumor that Maytag 92 model piston rings will fit a delco 850, is this true? Does anyone know where I could find rings for an 8c3 delco?
Old 12-03-2016, 07:08:05 PM
Default Re: Delco piston rings?
The rough Delco engine I have I put Maytag rings in it and they worked fine. I have no idea what exact model it is because it was just the engine with no generator stuff at all on it. Stuck,rusted up clunker that I was told I was stupid and a idiot to give 20 bucks for it and that it would never run.2 weeks later I sent the guy that called me a idiot a video of it running.
haven't run it since,As the timing marks were rusted away on the cam and I think I have it a tooth advanced. Gosh that has been 15 + year ago I did that.
Old 12-04-2016, 06:12:23 AM
Yes, Maytag model 92 piston rings will fit. Be sure to remove the cylinder and do a thorough hone job first. Then run it for at least three hours (with a load of a few light bulbs) to break them in. You'll be rewarded when it has more than the usual "ho-hum" compression afterwards!
Be sure to take a peek at the condition of the valves also, and at least give them a lapping.
Old 12-04-2016, 11:16:39 PM
So they do fit in an 8c3? I looked at them on eBay and it looked like just three solid rings where as I have to solid and a ribbed oil control ring
Old 12-05-2016, 12:25:42 PM
I know they'll work in an 850 but as for the 8c3...I can't say. However, you can buy any size/type ring you need from the Otto gas engine works, one of the supporters of this site. If he doesn't have it in stock, he can make it.
Old 12-06-2016, 02:49:26 AM
I messaged Otto rings with my measurements. I was just looking to see if anyone knew off hand what would fit
Using Rubber O rings for piston rings Roger U Scale Model Engineering 18 09-26-2011 06:55:35 PM
Delco 15c1 Piston Rings MBreen254 Generators & Electric Motors General Discussion 3 03-28-2008 10:28:59 PM
Piston rings for Delco Ronnie Dykstra Generators & Electric Motors General Discussion 4 07-08-2007 11:00:25 AM
Piston Ring Material for Custom Machined Piston Rings. Uncle Old Iron Antique Gas Engine Discussion 3 06-24-2007 01:50:53 AM
Piston Rings Charlie Bryant Antique Engine Archives 0 12-16-2000 12:26:02 AM
