1964 John Deere 1010 Crawler
this thread has 16 replies and has been viewed 1374 times
Old 12-18-2016, 08:55:11 AM
Derek Girard Derek Girard is offline
Default 1964 John Deere 1010 Crawler
Just wondering if anybody could give me any ideas... rebuilding a 1964john Deere 1010c crawler ... had no gas going into the engine so I rebuilded the carb same problem everything seems to ok in the carb ... just now she not flooding like before but & still no gas is getting into Engine ????
It would be greatly appreciated for any suggestions
Old 12-18-2016, 09:06:13 AM
Tracy T Tracy T is offline
Default Re: 1964 john Deere 1010crawler
If it's like other John Deere equipment it will have a screen in the tank, they get clogged.
The Following User Says Thank You to Tracy T For This Post:
Old 12-18-2016, 10:08:58 AM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
Images: 1
The tank is above the engine, no fuel pump. take off the line and open the valve. fuel should flow freely at the carb. line on there is a drain plug on bottom of carb, fuel should flow there also. make sure you did not miss a plugged passage in the carb.
The Following User Says Thank You to Tom Marshall Jr. For This Post:
Old 12-18-2016, 11:06:49 AM
Go flow to carb
---------- Post added at 07:05:37 AM ---------- Previous post was at 07:04:05 AM ----------
Good flow to carb
---------- Post added at 07:06:49 AM ---------- Previous post was at 07:05:37 AM ----------
I have good flow to carb
Old 12-18-2016, 11:28:18 AM
Is there fuel in the bowl? If so, hold your hand over the carb throat while cranking, do you have a strong suction, any gas in the carb when you let go? No vacuum, look for a bad intake leak or engine problems, plugged exhaust. Good vacuum, no fuel, go back in to the carb.
Old 12-18-2016, 11:44:18 AM
Good suction.... fuel in carb & pressure coming out exhaust .... couple of had back press come out the carb
Old 12-18-2016, 12:46:52 PM
Sounds like at least one intake valve is not sealing, check for spark if you have spark the ignition timing may need adjusted.
Old 12-18-2016, 01:16:30 PM
Perfect spark ...
Old 12-18-2016, 01:54:19 PM
Do a compression test, eliminate mechanical problems.
Old 12-18-2016, 02:07:41 PM
TomA TomA is offline
There must be intake valves not sealing (stuck, burned, tight adjustment) will neutralize intake vacuum.
The Following User Says Thank You to TomA For This Post:
Old 12-18-2016, 02:42:19 PM
If this machine has been sitting for any length of time I would do as suggested by jb before proceeding further. If you have stuck valves there is a good chance you have bent push rods, I ran into this with a air compressor about the same vintage.
Old 12-18-2016, 03:03:51 PM
stufforbud stufforbud is offline
This might sound impossible, but I would make sure there is no wasp or mouse nest up in the intake manifold. I repair magnetos and I find wasp nests inside when it appears there is no way they could get in there.
The Following User Says Thank You to stufforbud For This Post:
Old 12-18-2016, 03:47:43 PM
Ok thank I'll do that
Old 12-27-2016, 11:15:23 AM
How's it coming along? You know we like progress reports from time to time.
Old 01-24-2017, 09:30:08 PM
Didn't have much time to advance in my project since it's the winter haul.... but took time today and still no gas getting into engine so I took off intake all seems good nothing block and valve working like they should. Next step is im joint to empty gas since it's more then 2 years old and see if it will atomize more.
Old 01-25-2017, 12:06:30 PM
Peter Holmander Peter Holmander is offline
Default Re: 1964 John Deere 1010 Crawler
Derek, I used to own a 1010 gas machine like yours, but I sold it some years back. I think I still have an owners manual for it around here somewhere. I know I have the hood for it. I bought 2, one running and the other for parts. Was a good running machine.
Old 05-07-2017, 02:02:29 PM
Finally got the time to get back into the shop .... after all winter scratching my heard ... finally it was my firing order that was off ... I must of mixed it up two years ago , but now she running ....
John Deere 1010 Jon Nessel Antique Farm Tractors 13 12-30-2015 06:06:28 PM
John Deere 1010 Crawler LOADER Parts Catalog TractorDom Dozers and Crawlers 0 11-20-2015 07:26:51 PM
John Deere 1010 Crawler parts manual free download TractorDom Dozers and Crawlers 0 11-16-2015 01:18:47 PM
John Deere 1010 Crawler Keesie Vintage Diesel and Oil Engines 4 11-12-2009 11:44:29 AM
1010 RS John Deere Jerry Willis Antique Farm Tractors 3 10-10-2008 08:45:15 PM
