Need WW2 ac fuel pump diaphragm help
this thread has 5 replies and has been viewed 697 times
Old 12-21-2016, 09:29:21 PM
mschreiber mschreiber is offline
Default Need WW2 ac fuel pump diaphragm help
What do you guys use for ac fuel pump diaphragms, this is 3 1/4" diameter with 6 screw holes. i get a lot of confusing different info from google. this pump doesn't have a part number on the flange. thanks 4 any help.
Old 12-21-2016, 11:41:27 PM
David M. Lyon's Avatar
Images: 32
Default Re: Need WW2 ac fuel pump diaphragm help
I matched up a rebuilt A/C Fuel pump at Carquest auto parts for a '56 Chevy six cylinder pickup and bought it just to take it apart and get the diaphragm out of it. Worked perfect! ... $16.95 I think.
The Following User Says Thank You to David M. Lyon For This Post:
Old 12-22-2016, 03:23:06 PM
Frank DeWitt Frank DeWitt is offline
I bought a Viton sheet here http://r.ebay.com/TH6u4N Use the old one as a template and cut out a new one with scissors. I made the holes with a leather punch. It has worked for hundreds of hours.
The Following User Says Thank You to Frank DeWitt For This Post:
Old 12-22-2016, 04:02:02 PM
akuna akuna is offline
Isn't there a sponsor that sells pump kits and parts?
The Following User Says Thank You to akuna For This Post:
Old 12-22-2016, 07:44:21 PM
ordered. i didn't know which material to use between viton and bunda nitrile. google is kinda confusing about it, this is the endorsement i was looking for.
Old 12-23-2016, 02:33:33 PM
Viton is a great material. It lasts a long long time and resists more chemicals then any other rubber like material I know of. I learned about it when using O-rings in places where reliability mattered a lot more then cost. Parker recommended Viton every time. The only down side is cost. Because the Ebay rounds are leftover from there manufacturing process cost is not a issue.
Fuel Pump Diaphragm Material Dwayne Fuller Antique Autos and Trucks 14 04-05-2018 11:25:20 PM
AC Fuel Pump Diaphragm Ed Stoller Antique Gas Engine Discussion 5 05-19-2014 10:30:50 PM
Homelite Generator, Diaphragm Fuel Pump Matt C Generators & Electric Motors General Discussion 12 03-25-2014 01:57:38 PM
Kohler fuel pump diaphragm source Dmichels Small Air Cooled Gasoline Engines 15 07-15-2013 09:40:45 AM
fuel pump diaphragm Leonard Keifer Antique Gas Engine Discussion 2 06-19-2005 09:16:33 AM
