Wisconsin Engines
Wisconsin Information THD with Wico Model X XH-2531
this thread has 26 replies and has been viewed 2082 times
Old 12-22-2016, 11:47:14 PM
ti-jean ti-jean is offline
Photo Wisconsin Information THD with Wico Model X XH-2531
Hi today i went for a ride at a friends house is father die 4 mount a go I ad in is garage a Wisconsin thd twin cylinder i would like to turn that engin to see if ther is spark on plug to know if the mag is good but there is not crank at all no starter how dos engine was starded
and 50$ is that a good deal ?
thank
Old 12-22-2016, 11:56:43 PM
akuna akuna is offline
Default Re: Wisconsin information
thank
You took it home right? $50 is a deal.
The Following User Says Thank You to akuna For This Post:
Old 12-23-2016, 12:13:53 AM
oregonfarmboy oregonfarmboy is offline
That round ring or disc or what ever you want to call it on the pulley end is the way you crank that sucker. Looks like a motor that was on a New Holland something or other. Kind of like the flywheel start on old John Deere. Good luck. Keep us up to date on your progress.
The Following User Says Thank You to oregonfarmboy For This Post:
Old 12-23-2016, 10:49:55 AM
No it still at my friend house i was wondering if IL be able to get parts of all kind to fix-it and all that is I did'n buy it yet .
thanks
Old 12-23-2016, 01:31:02 PM
Trosky Trosky is offline
Yes parts are out there. I'm tearing down my THD now for a rebuild.
The Following User Says Thank You to Trosky For This Post:
Old 12-23-2016, 01:45:21 PM
For $50 you should go right over and get it before they change their mind or find a different person.
Even if the block was cracked you could sell the good parts and not only get your $ back, you would make someone happy that needed a part.
Sorry, have no idea how to start it.
Old 01-21-2017, 10:58:04 PM
Hi I am late but here frist Happy new years to all .
tomorrow i am going to get the Wisconsin
Old 01-23-2017, 01:05:25 AM
Photo Re: Wisconsin information
Houra the Wisconsin THD serial no 2860001 spec no 135622 is in my garage now I will figure how to get a spark on wire and plugs cause there is no spark
the megneto is a Wico Model X XH-2531 almost like my IHC 3to5 al so big job to do on the carburetor because the last owner fix a big harm to activate the governor what a mes .
I will need to read on to get that engine to run
Old 01-23-2017, 02:37:10 AM
Same Wisconsin as mean on that video
https://www.youtube.com/watch?v=FichFHcENow
Old 01-23-2017, 03:41:41 AM
Kris Golden Kris Golden is offline
Super engines and you got a good deal if it runs.
The wheel on the back side is for starting. Flip it counter clockwise. The mag should click loudly. If it does pull one spark plug [or at least the wire] and see if its throwing a spark. Both cylinders fire at the same time on that engine. One spark is wasted in the exhaust of the "other" cylinder.
I have heard several places to check the oil pump on one that has set for an extended time. To do that loosen the external oil line that is tucked in above the mag and spin the engine. If oil comes out and runs down the side of the block, all is good.
The Following User Says Thank You to Kris Golden For This Post:
Wico R1 information Tim B Oil Field Engines 0 01-30-2015 07:32:04 PM
Wico Igniter information Phil P Oil Field Engines 0 01-02-2010 05:57:53 PM
WICO mag on Wisconsin AEH gm1276 Wisconsin Engines 2 04-21-2009 11:46:06 PM
Wico OC Magneto Information ListerDiesel Magnetos, Ignition Coils and Spark Plugs 3 01-20-2008 05:33:05 AM
Wico FW Flywheel Magneto Information ListerDiesel Magnetos, Ignition Coils and Spark Plugs 0 04-29-2006 06:33:19 AM
