Wisconsin Engines
Wisconsin TD enclosure wanted
this thread has 4 replies and has been viewed 622 times
Old 12-23-2016, 08:39:26 PM
blacktinlizzie blacktinlizzie is offline
Default Wisconsin TD enclosure wanted
I am looking to buy all the sheet metal parts for a Wisconsin TD engine enclosure
I have the engine but need the enclosure to complete a project.
Old 12-24-2016, 05:35:27 PM
walker ar walker ar is offline
Default Re: Wisconsin TD enclosure wanted
I am not real familiar with all the engine designations, so not sure if they are the same or completely different. I have a complete running TJD that I am going to use the crank off of. If you want the sheet metal let me know.
Old 12-25-2016, 02:04:02 PM
medicaid medicaid is offline
Your request is for td ? Do you mean tjd or tfd or thd. I should have
all your are looking for . I am located in alaska, but frieght for light stuff, such as tin, will ship resonable. What is your zip code?
Happy holidays, dan
Old 12-25-2016, 05:14:46 PM
Yes I mean TJD or TFD
I am looking for the sheet metal enclosure
Hood, side panels, dashboard and front panel that the air cleaner housing mounts to the outside of and if there is one a base that holds everything together
Zip is now 05742 Vermont
Thank You Bill
Old 12-25-2016, 06:17:57 PM
CharlieB CharlieB is offline
I think that the OP is looking for what Wisconsin calls a "Power Unit" enclosure. ????
See page 4 of the manual:
http://www.kd5byb.net/Wisconsin/Manu...D%20Manual.pdf
Wisconsin engine tag wanted Skippy1969 Wisconsin Engines 3 04-08-2013 11:52:05 AM
Wisconsin ACN carb wanted Relic Wisconsin Engines 1 02-07-2012 10:05:58 AM
wanted any information on Wisconsin SU 4x5 truklodyte Unidentified Engines 0 12-18-2009 05:02:46 PM
Wisconsin VR4-D info wanted lsengle Wisconsin Engines 1 07-13-2009 05:50:28 PM
Wisconsin THD Help wanted 21avery Antique Gas Engine Discussion 2 01-01-2009 01:30:19 AM
