Oil Field Engines
Go Back   SmokStak > SmokStak® Antique Engine Community > Oil Field Engines
Oil Field Engines A gathering place for OFES members otherwise known as "Oafs". Basically, if you like "BIG OLD GREASY RUSTY OIL FIELD ENGINES, you're in the right place. Founded by Russell Farmer.
Oil Field Engines
Repouring crosshead babbitts?
this thread has 29 replies and has been viewed 3045 times
Old 12-29-2016, 11:30:57 PM
Default Re: Repouring crosshead babbitts?
Originally Posted by con-rad View Post
Skidmore,
After those bearings were poured, you had to machine them I assume? How did you determine the thickness needed for the bottom bearing? What did you use for your datum when you were setting it up in the mill?
Is there a reason these bearings couldn't be poured using the ways of the x-head as a mold?
conrad
They can be poured in situ. You may not get quite as nice of a pour, and it's a painstaking task, but it can be done. I helped set up and pour a 20 hp Bessemer crosshead, and I currently have a 12 hp Bessemer of my own that needs new babbitt. The challenges you will encounter are numerous. One, the damming process is tedious. You need to be certain there is relief on all of the surfaces apart from the slide surface itself. If the babbitt wraps up or down around anything, you'll have a difficult time getting it apart. Two, the molten babbitt is exposed to and must travel a considerable distance across cold cast iron. There is opportunity for the babbitt to chill before it completely fills the slide. Warm the casting a bit before you begin. Run the babbitt as hot as you can without overheating it. Vent the ends of the cavity well. And pour as fast as you possibly can. Clean everything extremely well beforehand. The slightest bit of oil or moisture will create a molten-babbitt volcano. If you've never poured bearings, this may not be a good first attempt. As I said, it can be done, and I'll probably do my 12 hp that way.
Be careful and remember to have fun along the way.
Kirk
Old 12-30-2016, 12:24:46 AM
Skidmore's Avatar
Skidmore Skidmore is offline
With the cylinder and piston still bolted to the bedplate and the head removed. Level the crosshead area of the bedplate side to side front to back. Unhook the connecting crank rod from the crosshead pull the piston rod back and put a small magnetic level on the piston rod. Measure the gap under your crosshead. Add a little, this will give you the thickness of your pour. To get the top pour reinstall the crosshead bars. Put a 1/16 or more shim under the mounting area for wear later. This will give you the thickness of the top pour. Having the head off you can screw the piston on and off the crosshead easy to do any fine tuning to you Babbitt once poured. No need for expensive milling. Use a flat knife to scrape any high spots off. Imperfections are just good spots to hold oil.
Skidmore aka engine hoarder
The Following User Says Thank You to Skidmore For This Post:
Old 12-30-2016, 01:03:15 AM
Skidmore's Avatar
Looking back at some other crosshead pours I have done. This one was very challenging. Top bottom and the sides, notice I used angle iron as my frame / dam. WV yellow Clay as my damming material. BD Tillinghast halfbreed on an Ajax steam bedplate.
Name:	Dads stuff 117.jpg
ID:	271342   Click image for larger version
Name:	Dads stuff 118.jpg
ID:	271343   Click image for larger version
Name:	Dads stuff 130.jpg
The Following 2 Users Say Thank You to Skidmore For This Post:
Old 12-30-2016, 09:36:03 AM
Thanks for the photos. I can see where setting up with angle iron would be much easier than pouring right on the bed plate. I have a long chunk of plate that I sometimes pour rods on; that would be a perfect platform for doing the Bessemer crosshead. With everything set up on angle iron, the entire assembly is easily dammed and could be heated to get a nice pour with not-so-hot babbitt.
Thanks again for the input.
Kirk
Old 12-30-2016, 01:43:31 PM
Thank you for the good info Skid but please elaborate on this quote. Bill Klein
Old 12-30-2016, 09:00:58 PM
Skidmore's Avatar
With the head removed you can use a socket and ratchet to thread the piston and rod into the freshly poured crosshead rather than using a pipe wrench on the rod. That takes forever. Once threaded together you can slide the crosshead back and forth, disassemble and you will see any high or tight spots. Then do a little fine tuning with a new utility knife blade. Scrape away a few thousandths were needed.
ID:	271394   Click image for larger version
Name:	Dads stuff 131.jpg
Old 12-31-2016, 07:39:10 AM
con-rad con-rad is offline
Ok, I think i got you now. So after you assemble the cross head with no babbitt and make measurements, you fabricate your dam exactly to those dimensions. When you pour, the x-head must be perfectly level so the babbitt levels out, and the poured surface is flat enough so that with a little scraping afterward, it is a finished surface. Is that correct?
With that process, there isn't any issue with the top surface of the babbitt caving in a little bit, due to cooling shrinkage? that would ruin the flat surface.
connor
Old 12-31-2016, 08:31:01 PM
Skidmore's Avatar
Yes you got it with a little scraping thats the finished surface. no problems with the top or bottom sinking. It would sink in if you preheated to much and soften your first pour but it takes a lot of heat to melt babbitt.
Old 01-02-2017, 12:19:10 PM
Preheated the babbitt too much or the x-head too much?
connor
Old 01-04-2017, 11:09:55 PM
So here's another babbitt bearing question, thought i'd ask here rather than make another thread.
As you can see in the photo, one of my bearing caps is broken so the babbitt needs to be melted out so it can be brazed together again. My question is what is the best way to pour that bearing half? it is best to use a dummy mandrel or use the crankshaft itself? I'd like to use the crank but it seems like damming it would be a challenge. any other wisdom?
Thanks!
connor
Bessemer crosshead gw765 Oil Field Engines 3 11-11-2012 07:22:16 PM
repouring a rod bearings ehpower2 Antique Gas Engine Discussion 3 07-25-2011 05:20:30 PM
Crosshead Shoes JBoogie Steam Stationary Engines, Traction Engines, Steam Boats 0 11-03-2010 12:27:25 PM
Babbitts turning to powder and wont come off Christopher Underwood Antique Gas Engine Discussion 1 09-09-2009 11:15:18 PM
Need New Babbitts Christopher Underwood Antique Gas Engine Discussion 1 08-27-2009 06:26:28 PM
