Twin City KT water pump
this thread has 10 replies and has been viewed 845 times
Old 01-02-2017, 12:06:23 AM
patchen1 patchen1 is offline
Default Twin City KT water pump
I have a 1931 KT and the water pump is completely shot. Does anyone have or know of one that could replace mine?
I was curious if a water pump from an early 1 piece block U Moline would fit?
Old 01-02-2017, 02:46:33 AM
ajs2744TC ajs2744TC is offline
Default Re: Twin City KT water pump
Where you at in MN?
Old 01-02-2017, 03:20:41 AM
I'm in West Central Minnesota, close to Alexandria. If that helps any. I used to get up your way when I was in the National Guard.
Old 01-02-2017, 07:03:09 PM
Molinegb Molinegb is offline
Pump shaft is different as KT uses for mag drive. U uses a brass impeller with left hand thread. KT uses packing and nut. U has rubber seal. Nothing is the same. Have some KT pump parts but under 3 ft of snow.
Old 01-02-2017, 08:31:16 PM
When the snow melts if you could take a look for the KT parts, it would be appreciated. I am told that we are going back into the deep freeze here in Western Minnesota.
Old 01-03-2017, 12:49:38 AM
What happened to your water pump that makes it irreparable?
Old 01-03-2017, 01:33:08 AM
It has been sitting and rusting away for as many years as I have known about the tractor and longer. There was a repair date on the inside of the magneto that said April of 1945. I am not sure what happened or how the tractor ended up in an one running condition, I do know so far that 3 of the 4 connecting rods are bent.
Old 01-03-2017, 06:01:13 PM
Conn rods are same as U up until KEF motor in 1940.KE 376B Rod bearings same also (KE383) babbited. Pistons,block and head also same up until twin block U in 1948. Manifold same until until 1941. Early KT had different manifold.
Just double checked in books and no waterpump parts are same.
The Following User Says Thank You to Molinegb For This Post:
Old 01-04-2017, 10:35:05 PM
If your water pump isn't cracked or broken it could probably be repaired. It looks like a pretty straightforward assembly.
Name:	TC 20-35 Canadian 1 053.jpg
Old 01-05-2017, 09:57:22 AM
Know there is something in the pump that is to make or find. Sold some pump parts to a fellow collector in TX.
Twin City 17-28...My Intiation into the Twin Cam Faternity! Mark Schneider Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 115 04-03-2018 09:26:40 PM
New Member of the Twin City Twin Cam Fraternity J Ware Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 22 09-06-2017 12:25:53 PM
Onan 30EK city water model water pump impeller? Pete Spaco Onan Generators 9 06-12-2011 02:36:49 PM
Maytag Twin with Water Pump Base Chitty Chitty Bang Bang Maytag Engine Collectibles 4 05-06-2009 04:38:48 PM
Cushman 8 hp Twin water pump shaft. Jim Gorter Antique Gas Engine Discussion 2 07-24-2008 03:59:19 PM
