what engine does this carb on tank fit?
this thread has 3 replies and has been viewed 607 times
Old 01-03-2017, 05:44:22 PM
Default what engine does this carb on tank fit?
I would like to list this on ebay or help out somebody that needs it. I have had it for years and have NO idea what it fits. It is odd in that the air filter looks like a Clinton,but the carb design is like the old Briggs carbs. Gas tank is in perfect shape,carb is fine, I guess I need to clean off the old bummed up gasket so it won't look so bad. But I would appreciate a idea of what it fits.
I used google image to look at vertical engines of both briggs and clinton and nothing comes up the same.
ID:	271667   Click image for larger version
Old 01-03-2017, 06:55:11 PM
Default Re: what engine does this carb on tank fit?
I know it's Briggs, and I've seen it on some of the early vertical mower engines. Not sure of model no. something in the 6's
Old 01-03-2017, 08:33:21 PM
Partsman Partsman is offline
Card Sponsor
Hi It's off a Tecumseh engine built for Crapsman. It fits a LAV 30 Spec numbers 40168A and 401271G & H. Part number for the carb. body is 32228. Jim
The Following 2 Users Say Thank You to Partsman For This Post:
Old 01-03-2017, 11:54:46 PM
thank you. I have wondered what the heck it fit for a long time.
5hp brigggs, carb to tank gasket leaks uglyblue66 Garden Tractors / Mowers / Scooters 7 03-26-2015 10:39:57 PM
Tom Thumb gas tank & carb needed oeisales Antique Gas Engine Discussion 10 02-06-2013 02:26:59 PM
10HP Tank Cooled FM carb Doug Waggonner Antique Gas Engine Discussion 9 10-28-2008 11:32:05 PM
Leak between tank and carb ldj1002 Antique Gas Engine Discussion 5 04-22-2005 07:55:10 PM
Briggs Model U with Under Carb Gas Tank Mike in NC Antique Engine Archives 3 03-01-2003 05:21:41 PM
