32 volt motors
this thread has 13 replies and has been viewed 1069 times
Old 01-06-2017, 08:53:40 PM
Noyes Noyes is offline
Default 32 volt motors
I have recently rescued 2-32 Volt DC motors. One is a Primrose from International Harvester I think from a cream separator. The other one the tag is partially missing. Any advice on restoring?
ID:	271863   Click image for larger version
ID:	271864   Click image for larger version
Old 01-07-2017, 02:40:03 AM
Default Re: 32 volt motors
My opinion on restoring.... Disassemble and separate any bearings, soak the rest in water several hours. Agitate. Rinse and repeat. Don't use solvents as they might damage varnish insulation. Let air dry for several days in very warm area, such as over or by a heat duct. Scotchbrite commutators being careful of connecting wire area. Treat commutator with very light coat of cramolin (deoxit) paste. Soak bearings in solvent and make sure to wash out any dirt. Dry with compressed air and lube. Reassemble and test.
Doc
This line left intentionally blank...
Old 01-07-2017, 11:02:05 AM
Tim B's Avatar
Tim B Tim B is offline
Nice find you lucky dog! Your suppose to use a commutator stone to clean the commutator, but I don't have any so I just use sandpaper. DO NOT use emery paper! Remove the brush and lay the paper over the commutator to clean. then reverse the paper and seat in the brushes. I got this from one of my original lightplant booklettes. I talked to a guy in a motor shop that told me they pressure wash motors and bake them afterwards to dry them. I cant remember at what temperature though. Wasn't much, I can find out Monday.
The Following User Says Thank You to Tim B For This Post:
Old 01-07-2017, 12:33:06 PM
What you need now is a power supply. I built one using a 7.5 amp variac , a full wave rectifier . and necessary meters. If I built another one I would use a 15 amp variac. See pics.*** http://www.smokstak.com/forum/showth...t=74918&page=2 ***Ron
The Following User Says Thank You to Ronald E. McClellan For This Post:
Old 01-07-2017, 12:34:22 PM
Radiomike Radiomike is offline
The advice given by Doc seems sound. If possible use deionised water (Reverse osmosis or distilled); no dissolved salts present. An alternative is a small steam cleaner often sold for domestic cleaning. Still need to dry it out very thoroughly.
Avoid any silicone based solvents as they do not play nicely with commutation conditions.
Make notes of any connections, I guess these motors are simple shunt wound devices.
Carefully measure the field coil resistances both for continuity and to frame. Don't use a high voltage insulation tester. Check the armature from commutator segment to segment, adjacent ones and work round. Check the commutator to shaft. Do these tests before and after your restoration.
A coat of new electrical varnish is always a good idea once it is all sparkling clean.
Mike
The Following User Says Thank You to Radiomike For This Post:
Old 01-07-2017, 08:21:20 PM
What is cramolin paste? And what is used for? Where can it be purchased? What is electrical varnish? I am planning to run motors with a stearns light plant. Thanks for all the help
Old 01-07-2017, 09:07:22 PM
Not sure about cramolin paste........but red, spray-on varnish it readily available on Ebay among other sources.
The Following User Says Thank You to George Andreasen For This Post:
Old 01-07-2017, 11:19:11 PM
Electrical varnish is available, I bought some at my local paint store. I expect the original colour was however probably black. If you get some, and a local rewind shop may give you some, make sure it is "air drying" type.
This is just one supplier http://www.electro-wind.com/dolph-sp...can-449-g.html
One further point, the commutator has lots of individual segments, separated by insulation often mica based. It is important that any debris is removed from the gap between each segment. A scrub with some electrical solvent and a toothbrush is a good start. Sometimes the mica is flush but most often it is slightly undercut. A glass fibre commutator stick is a good tool to use on the surface. The operation of the commutator and brushes depends on a patina developing on the current carrying part of the commutator. A clean surface is needed but not necessarily a mirror finish.
http://www.anglocarbon.com/acatalog/...eequipment.htm
Also what were the two field coils in one of the photographs, they looked to be from a bigger unit?
Mike
Old 01-08-2017, 10:59:57 AM
Thanks for the advice. I think the other field coils are from a Stearns light plant dynamo. I salvaged the light plant from the same building. The previous owner was a salesman for Stearns, Hope to find more artifacts and infor on this company.
Old 01-08-2017, 02:12:18 PM
Cramolin, now renamed Deoxid, is the finest contact treatment in existence. Thinner versions are used to treat potentiometers and contacts. Here's a link to makers store. I still have a small quantity of the paste from back in the eighties. I use it on flashlight battery contacts. Read application info on site. http://store.caig.com/s.nl/sc.2/.f
Doc
Sigh... Looks like they discontued most their specialty lubes. Their Fader Grease is as close as they still make. Sad.. they used to offer grease with copper dust and the like.
Interesting---12 Volt Lights off 24 Volt Generator MEP=016b SDHomesteader Military MEP and Aircraft Gen-Sets 10 10-16-2009 08:56:53 PM
ancient 32 volt electric motors rambill Farm + Industrial Antiques and Collectibles 4 03-07-2007 03:58:01 PM
32 volt yes, 32 volt auto start Kohler Frank DeWitt Kohler Generators 4 08-01-2005 08:54:08 AM
32 Volt Motors Mike in NC Generators & Electric Motors General Discussion 2 02-16-2005 08:40:15 PM
110 volt DC Motors Philip Eggen Generators & Electric Motors General Discussion 5 04-09-2004 11:12:07 PM
