Wisconsin Engines
Wisconsin Single
this thread has 7 replies and has been viewed 796 times
Old 01-10-2017, 05:07:10 PM
Greg M Greg M is offline
Default Wisconsin Single
Looking for information on this Wisconsin single. Tag is missing.
The electric starter was installed by the PO. It's off an outboard motor.
Thanks!
Old 01-10-2017, 07:15:58 PM
Zira Zira is offline
Default Re: Wisconsin single
AGN or AGND.
Old 01-10-2017, 10:44:55 PM
s100 s100 is offline
Default Re: Wisconsin Single
Zira nailed it. To add to what he said, these are 12HP engines and are about as good an engine as you can find in that power rating. With just a bit of care and proper use they will last forever. The clutch is a nice feature as well.
If you start using the engine, be sure to get the proper sheet metal cover over the starter pinion. You'll be losing cooling air otherwise.
Old 01-10-2017, 11:11:30 PM
Thanks Zira and s100. Good call on the cooling shroud. I'll do something about that.
I got it running today. It hasn't run in years apparently but with a bit of coaxing she fired up. Really liking that electric start :-) The gear won't shift so I'll be tearing into that.
Is there a manual available somewhere for download?
Old 01-11-2017, 06:41:46 AM
Phil P Phil P is offline
Hi
I would recommend not running it any longer until you remove the oil pan and make sure the oil pump is working.
That engine used a plunger type oil pump and the check balls have a bad habit of sticking to the seat causing it to not pump.
Phil P
Old 01-11-2017, 10:45:59 AM
Thanks Phil P. I assumed this would be splash lubricated. I know nothing of these engines. Thanks again.
Old 01-11-2017, 10:12:43 PM
Actually you are both right. The oil pump pumps the oil up into a little trough, where the connecting rod splashes it around just like you'd expect.
The Following User Says Thank You to s100 For This Post:
Old 01-13-2017, 07:47:24 PM
I have a scan. PM me your email.
Stromberg ML 16 for Wisconsin Single cylinder TractorDom Carburetors, Mixers, Fuel Pumps and fuel delivery 0 11-15-2015 10:15:16 PM
Wisconsin AHH 9.2HP...largest single cyl made by them? johnnyrock70 Wisconsin Engines 8 12-07-2014 10:19:20 PM
Wisconsin Single Cylinder Rod Lengths Question cubcadet70 Wisconsin Engines 5 09-28-2013 07:50:34 PM
Wisconsin single cast iron hand crank eng. beaudoin45 Unidentified Engines 2 05-07-2012 10:45:47 PM
Large Single Cylinder Wisconsin John Schwiebert Wisconsin Engines 12 04-11-2009 08:39:17 AM
