Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Horse Drawn "Standard Oil" Fuel wagon on auction.
this thread has 41 replies and has been viewed 19731 times
Old 10-03-2011, 01:35:55 PM
Avery22x36 Avery22x36 is offline
Default Re: Horse Drawn "Standard Oil" Fuel wagon on auction.
Sure Tom, I will have to dig out some disks since the computer at the time has "passed away". The serial number is under the seat on each side painted between the two rods that sandwiched the tank between the seat and the frame. Both of my tanks came from Kansas and were prop of Standard Oil of Indiana so I am not sure all of them painted them there. In the 20s the early truck tanks had the number stamped on a plate and welded on the tank with three tacks so dirt always got behind it and rusted it out. I will try to find some pics, Aaron
Old 10-07-2011, 11:10:14 PM
I got one of both sides of the front under the drivers seat with the serial numbers but I will have to download if onto the computer again. I took plenty of pics if there is anything else you need, its just how it looked after sand blasting. Hope this helps, Aaron
The Following 2 Users Say Thank You to Avery22x36 For This Post:
  #23
Old 10-08-2011, 10:21:42 PM
Mike Rock Mike Rock is offline
I need help. I bought a tank like these two years ago on eBay.
I paid for it and never heard from the guy again. I needed the address or lat/long to find it. It is near Ft. Pierre, SD. It is an old WNAX fuel tanker tank. They were able to sell fuel really cheaply by delivering in bulk.
If anyone near Ft. Pierre knows where this rascal is sitting I would be MOST grateful to find it.
I don't think the seller was malicious or anything, we just lost contact and I was undergoing some cancer fun at the time so my attention span was not the best! Fine now, or at least a lot better than I was.
Most respectfully,
Mike Rock
It was doing duty as a water tank when I bought it. Bottom is rusty but holds water. I want to make a water tanker on running gear like it was... water for horses when working away from house.
Old 10-10-2011, 10:51:42 PM
Mike, those oil wagons are pretty valuable you know? They are also compartment wagons so they don't make the best waterwagons.
Old 10-10-2011, 10:55:33 PM
John Hanson John Hanson is offline
Mike, you might post your inquiry over on draftanimalpower.com
I know there's some guys from SD there, and they're into horsedrawn stuff, so it may be a good chance they'd know of that wagon.
Good luck!!
John
Old 04-25-2012, 02:40:16 PM
OTTO-Sawyer's Avatar
Photo Re: Horse Drawn "Standard Oil" Fuel wagon on auction.
I found this neat Cabinet Photo picture on eBay showing a Horse Drawn oil tank. Location unknown but apparently the Photographer or photo developer was from Rock Island Illinois, so presumably the oil tank was from there or near by as well.
It's a bit pricey at $35.95 for a 4x6 picture on a 7 3/4 x 9 3/4 board, but it is a pretty neat old picture.
Auction number 300599963804 has 16 days left on it, so it looks like it's a 30 day listing and will likely be relisted if it doesn't sell, so the number should be good for a while.
I downloaded and sharpened the picture a little to post it here. The original SHOULD be even sharper yet as most cabinet photos are, but the shot that was uploaded to eBay and then downloaded by me is a bit grainy and there's only so much you can do with that.
Interesting to see that even though it should have been relatively new in the picture, it has a pretty good sized dent in the side of the tank. Also has a Convertable Buggy Top for the driver, as seen a little better in the cropped picture.
Figured I'd post it here and update this thread, along with checking to see if anyone was able to help Mike locate his as mentioned in post #23.
Name:	Horse Drawn oil wagon in Rock Island Illinois.jpg
ID:	134064   Click image for larger version
Name:	Cropped Copy of Convertable top.jpg
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
  #27
Old 05-29-2012, 11:42:40 PM
ranks23 ranks23 is offline
I have an old fuel wagon tank at home. It is a different shape than most though. It isn't as round as all of the ones I have seen. Has anybody seen one like this before?
It has almost a flat bottom and straight sides with a slight round top. Also has 3 seperate compartments. Any help would be appreciated. Thanks in advance!
The Following User Says Thank You to ranks23 For This Post:
  #28
Old 06-06-2012, 05:43:58 AM
Ranks23, I believe there is one like this in Liberal Kansas, its been a while since I saw it but think it had an oil company plate on the rear axle? I will look through my pics and see if I can find it for you. I only remember it because it was unusual and pretty neat all around.
The Following User Says Thank You to Avery22x36 For This Post:
  #29
Old 06-08-2012, 11:19:07 PM
Avery22x36, Thanks for your reply. Any other help on my fuel wagon would be appreciated. It is also for sale if you know of anybody that may be interested.
Old 04-13-2013, 11:08:34 PM
Got to watch Another One sell at auction today.
This one, the tank itself was in good shape, and it had most of the running gear under it, though one back wheel was busted up pretty bad. Other back one was somewhat rotted. I didn't look at the front ones that close, other than to notice that they seem a little big compaired to other ones I've seen.
This one also had the box with it, though it was setting on the ground in front instead of hanging on the back.
Sold for $1050.00
Auction also had a 5hp Monitor Saw Rig that sold for $1750.00 an old flour mill that had some damage and parts missing but was still pretty nice overall that sold for $60.00 and a neat old wooden horse drawn water tank that I didn't stick around long enough to see what it sold for. There was also a neat little Dog Treadmill power unit, but I wasn't paying attention to hear what it sold for.
Got to see some of my Dad's handywork on an old 1907-1909 Deere & Mansur 5-10 horse power-unit that sold for a whopping $5100.00 with a telephone bid sending it to Montana. The power unit (or a couple parts of it anyway) was bought by Robert Lamm back in 1979, and My Dad welded some of those parts back together, and then fabricated all of the missing parts that I snapped several pictures of just to compare his parts with the originals. Had to look pretty close to find some of them.
I might post some pictures of some of the other stuff later in another thread and try to keep this one on the oil tanks.
Name:	4-13-13 Picture 001 (24).jpg
ID:	162780   Click image for larger version
Name:	4-13-13 Picture 001 (25).jpg
Last edited by OTTO-Sawyer; 04-14-2013 at 12:09:16 PM. Reason: Had wrong date on the Deere hp unit
Please help with horse drawn wagon JerseyBob Horse Drawn Equipment 1 08-04-2010 11:46:13 AM
Horse drawn equipment & threshers at Auction Doug Kimball Farm + Industrial Antiques and Collectibles 0 04-08-2010 09:49:37 PM
Johnson Iron Horse AX479 with "unique" gas tank Kammer0072000 Small Air Cooled Gasoline Engines 0 07-27-2009 12:34:06 AM
Length of tongue on horse drawn wagon or engine Gene Fisher Horse Drawn Equipment 12 05-11-2009 12:55:16 AM
Domestic horse drawn wagon? ssimntih Horse Drawn Equipment 1 10-07-2006 12:12:29 AM
