Welding Shop
Help with a Miller 44D Trailblazer Welder
this thread has 3 replies and has been viewed 4455 times
Old 02-28-2014, 10:25:58 PM
tdarden tdarden is offline
Default Help with a Miller 44D Trailblazer Welder
All
About 3 years back I acquired a Miller TrailBlazer 44D with a Perkins 4-154 engine. I have never heard it run , even though the hour meter shows only about 100 hours. 1982-83 model. Few parts were missing and when I finally found them the engine appeared frozen, but it was not 9 months earlier.
I have found in forums a procedure to hopefully un-sieze the engine but that is not my question. I suspect that the unit has not been run in over 20 years.
My question is, (1) is there any way that the injection pump could still be functional ?
(2) Also where do you go to get an injector pump tested ?
(3) I have also read that with injection pumps there is a procedure that you must go through to both remove them as well as re-install them ?
Don't know squat about Diesels. Any help would be appreciated? If I am on the wrong forum please direct me to the proper one.
Old 03-01-2014, 09:15:59 AM
Husky Husky is offline
Default Re: Help with a Miller 44D Trailblazer Welder
www.weldingweb.com
Old 03-01-2014, 11:05:22 AM
dkamp dkamp is offline
eMail NOT Working
I'm no diesel expert, but the very, very first thing I would do, is pull off the injection pump, because... if it's stuck, and you try turning the engine, the result would damage a very, very expensive piece. It IS timing sensitive, so ther'es a procedure for reinstalling it to proper synchronism.
Old 03-01-2014, 12:35:07 PM
Toesmack's Avatar
Toesmack Toesmack is offline
I have fired many diesel tractors and engines that have not run in 10 to 20 years. Often they fire up in the first 2 or 3 revolutions! Injection pumps will hold up just fine in storage provided they have clean fuel in them. Water is the real enemy here. Get the instructions on removing and reinstalling/timing your pump before removal. Usually pin the engine at TDC and mark the pump flange to timing cover area with a metal scribe before removal. Some pumps come off with the shaft in place, others will leave the shaft behind. Remember, this is the same as a distributor on a gas engine. Timing is critical.
Testing is often free if you have a good diesel shop. Overhaul is not cheap. $600 to $1200 is not unusual. You might as well pull injectors also, very easy to test, and it may allow you to get the engine rolling over.
Good luck!
The Following User Says Thank You to Toesmack For This Post:
Miller welder/generator help please. envelopes2007 Welding Shop 4 03-24-2010 02:39:32 PM
Miller Roughneck 2E Welder teppler Welding Shop 2 02-08-2010 07:33:18 PM
Old Miller welder model 61 p knightsun Welding Shop 2 09-17-2009 11:37:03 AM
Miller Welder mig gun holder. aametalmaster Welding Shop 5 07-10-2009 10:16:01 AM
miller welder sparkplug54 Welding Shop 0 12-03-2006 06:24:02 PM
