Guesstimate on the weight of a 15.0JC 18-R
this thread has 3 replies and has been viewed 345 times
Old 04-28-2018, 09:45:59 PM
wxyoung2008 wxyoung2008 is offline
Email NOT Working
Default Guesstimate on the weight of a 15.0JC 18-R
Would any of you know what the weight of a 15JC -18R would be or give me a good guess ?
Thanks
Old 04-28-2018, 09:50:43 PM
DMeed DMeed is offline
Default Re: Guesstimate on the weight of a 15.0JC 18-R
Do a search for the spec sheets somewhere here, but I would ballpark in the 850 lb range
OK look at the stickies in the sales literature thread - post 4 has the jc cut sheets.
https://www.smokstak.com/forum/showthread.php?t=80597
That shows 675 lbs - guess I was a bit over. Don't know why I had 850 in mind.
The Following User Says Thank You to DMeed For This Post:
Old 04-28-2018, 09:51:22 PM
Jim McIntyre's Avatar
Jim McIntyre Jim McIntyre is online now
682 pounds
The Following User Says Thank You to Jim McIntyre For This Post:
Old 04-28-2018, 10:04:52 PM
Email NOT Working
Thank you both !
IHC LB 3-5 HP Weight jboyer1028 Antique Gas Engine Discussion 3 01-24-2014 09:20:11 PM
Weight of a JC 20 hp deadend Oil Field Engines & Related Equipment 12 12-02-2013 02:32:33 AM
IH M 6 HP weight Russ Hamm Antique Gas Engine Discussion 3 11-03-2013 01:27:19 PM
weight id? Scott Oil Field Engines & Related Equipment 1 08-27-2013 09:29:02 PM
GM 6-71 Weight? Walter J. Generators & Electric Motors General Discussion 5 09-10-2007 11:36:24 PM
