Running a JB in an enclosed space and..
this thread has 23 replies and has been viewed 2922 times
Old 10-31-2012, 08:48:37 PM
AndersonMillTexas AndersonMillTexas is offline
Default Running a JB in an enclosed space and..
Hi everyone,
The weather cleared up and I am about to move my newly aquired 7.5 JB 3CR to the out building.
I want a comfortable place to do my tinkering and possible make this little strucure d its pemenant home.
It is 10' x 12' with a an 8' ceiling and an attick above that. Standard 2x4 construction. Plywood sheathed and cedar shingles but no insulation. Two windows a door and a double door.
I was thinking of poping the exhaust out the side or though the roof. No other special venting.
Do you think it will over heat? will it be over kill to creat ducting or just stick a fan in the window or prehaps leave a door open.
How about a temp gauge on the generator housing or engine block?
Thanks for your ideas.
Old 10-31-2012, 08:58:57 PM
MBB MBB is offline
Default Re: Running a JB in an enclosed space and..
I believe Jim Mcintires setup he has a fan running off the AC of the unit to pull the hot air out. If you do that you should have some fresh air vents to suck air in.
The Following User Says Thank You to MBB For This Post:
Old 10-31-2012, 08:59:02 PM
Ray Cardoza's Avatar
just run it through the side not the roof
The Following User Says Thank You to Ray Cardoza For This Post:
Old 10-31-2012, 09:04:02 PM
EnginePat EnginePat is offline
I ran the exhaust thru the wall and down to a trench about 2' deep into a clay thimble and a 20' plastic pipe and back out works great.
Pat
5GO 3/RA
7.5 jb's x3
The Following User Says Thank You to EnginePat For This Post:
Old 10-31-2012, 09:08:03 PM
I will try and find jims set up through forum search.
Thank you
Old 10-31-2012, 09:14:55 PM
Isnt that quite a bit of back pressure? That is like a 24' run. Why not have it poke out through the roof or wall.
MMM! I could make a plywood with a hole in it and close the window down on the plywood. I wood just pop into place when needed.
Name:	The little shed.jpg
Old 10-31-2012, 09:18:06 PM
What is a clay thimble?
Old 10-31-2012, 09:29:31 PM
Jim McIntyre's Avatar
Nothing too unique about it - I just stuck a fan in the wall. Works well so far...
http://www.smokstak.com/forum/showthread.php?p=662516
Old 10-31-2012, 09:33:35 PM
Jack Hottel Jack Hottel is offline
Clay thimbles are terra cotta pipes used where smoke pipes connect to brick and mortar chimneys. Not combustible and heat resistant, qualities you need where a possibly red hot exhaust pipe penetrates a wall or roof.
Duct the hot cooling air from the engine and generator outside. Have vents for incoming air, not on the same wall. The generator has plenty of fan to keep itself cool if you don't let the air recirculate.
Jack Hottel
The Following User Says Thank You to Jack Hottel For This Post:
Old 10-31-2012, 09:34:53 PM
Go to your local big box store and buy a 3 inch double wall thimble used for pellet stoves. These have enough clearance to keep the combustable away from hot exhaust. Get a 16" long piece of 3" double wall pipe to fit into it. there is a matching galvanized collar to fit over the outside. and seal it from critters.
this will cost you around $25.00 total with tax.
your JB uses a 1 1/2 " exhaust pipe so you can put some copper mesh around it in the pipe to seal the double wall .
X-tra Space , No Problem Paul Spence Antique Engine Archives 0 07-27-2003 11:21:18 PM
Re: Space David Greenwalt Antique Engine Archives 0 10-10-2002 09:36:40 PM
What about your trailer? Enclosed? Leroy Clark Trucks, Trailers and Hauling for Shows 12 02-24-2002 10:35:45 AM
ISP Provider Web Space Bill in PA Antique Engine Archives 1 01-20-2002 09:29:16 AM
