Onan JB/JC High Compression Pistons
this thread has 26 replies and has been viewed 1562 times
Old 05-17-2016, 11:24:26 AM
Default Onan JB/JC High Compression Pistons
Well, I'm thinking about seeing if anyone has a set of 4 high compression pistons that they want to sell. Since I can't get full A/C output on my JB I would imagine it will be the same for a JC I have torn apart and think I might go with the high compression pistons because of living @ 8,700'.
Pistons for sale or comments anyone????
Old 05-17-2016, 11:33:33 AM
KPack KPack is offline
Default Re: JB/JC high compression pistons
What's the parts number , we can search too.
Old 05-17-2016, 12:16:32 PM
Motorhead's Avatar
I think Jim McIntyre milled the head on a JB to raise the compression. What fuel are you running?
Old 05-17-2016, 12:36:58 PM
Jim McIntyre's Avatar
Nope. I would if I had an extra JB head to tinker with. I have done this on several CCKs with success...
Old 05-17-2016, 01:02:22 PM
Piston # 112-0174 Std. bore
112-0174-10 .010
112-0174-20 .020
112-0174-30 .030
I will be using either gasoline or propane, mostly propane but, if I needed too I would run gasoline.
Really looking for STD. bore pistons.
The Following User Says Thank You to nothingbutdarts For This Post:
Old 05-17-2016, 01:06:17 PM
Motorhead's Avatar
Someone tried it here on the site. Can't remember who.
The only other way I would think of gaining power for altitude loss would be turbocharging with a small amount of boost. Use a small turbocharger like the ones used on the Kubota diesels.
Old 05-17-2016, 01:10:51 PM
Gunny Gunny is offline
Can't get full AC power?
What happens? What is the indication you are not getting full power? Frequency drop off, voltage drop off?
Old 05-17-2016, 01:26:14 PM
Or get creative and use a supercharger, I know there is a small Mazda supercharger on ebay right now
Old 05-17-2016, 02:02:33 PM
Motorhead's Avatar
Here you go....
http://www.theboombopshop.com/Garret...ett-gt1241.htm
Old 05-17-2016, 02:34:31 PM
I have run 2-6.5NH's, a DKD and a JB, none will get full A/C output. On all, the throttle is wide open and the HZ/RPM just starts dropping.
If you refer to the charts on here you will see Onan's derating figures:
http://www.twinslan.net/~n0nas/manua...%20GenSets.pdf
I figure I would not put a turbo on it, lots of money and modifications so I figured if the compression was raised that would help gain back some lost horse power because of the altitude.
JB & JC High-Compression Pistons OnanParts Onan Generators 30 04-06-2017 02:49:30 PM
High Compression Pistons Crankpot Onan Generators 21 04-03-2017 09:56:03 AM
Onan 7.5 jb high vs. low compression engine Ray Lynch Onan Generators 44 12-27-2014 11:06:18 AM
Question: High compression pistons for CK&CCK? John Kendrick Onan Generators 7 04-28-2009 06:14:18 AM
