onan 30 kw
this thread has 2 replies and has been viewed 2935 times
Closed Thread
Old 02-21-2004, 08:38:04 PM
texan0924
Default onan 30 kw
i have a onan 30 kw 4 cyl diesel, mod# 30.0 DEH-15R/1092D SER# 0673659591 AFTER A FEW MINUTES OF RUNNING AND GENERATING POWER, THE VOLTS MAX OUT AND TRIPS MAIN CB, I WOULD GREATLY APPREC. ANY HELP. tHE INSIDE OF THE CONTROL PANEL HAS SEVERAL CURCUIT BOARDS (2) 240 VT AC RELAYS AND (2) 12 VOLT RELAYS
Old 02-23-2004, 10:17:35 PM
Dennis Risser
Default Re: onan 30 kw
Hello,
The overvoltage is usually caused by a defective voltage regulator. It sounds like you have an intermittent bad connection within the sensing circuit. I can get your board tested or rebuilt, or you can replace it with a less expensive after-market regulator. You can e-mail me: parts@partsfortechs.com or call my tech help line at 717-274-9396.
Regards, Dennis
Old 12-26-2004, 10:03:20 PM
hell6789 hell6789 is offline
hi texan
there is several places you can find parts but the reason i am writing you is i have the very same problem you have with your gen but some wires are cut and i am ask you as a favor some pictures of your gen on the starter side of the unit i need to know where the wires go on this side as some someone decided to cut them off. a pic is worth a thousand words. you can get rebuilt voltage reg from www.
flightsystems.com you can email me at popscat@aol.com if you like
Closed Thread
