Help With Briggs and Stratton
this thread has 5 replies and has been viewed 517 times
Old 06-17-2018, 10:54:48 PM
Shamus1 Shamus1 is offline
Default Help With Briggs and Stratton
Hello to everyone, new user and seeking some assistance. I have a Briggs and Stratton single cylinder engine with a manufacturer's plate that is very difficult to read. I have determined the above info and a model number, engine type number and code number, in the above order they are; 23A FB, 703692, 793546. I believe it to be circa 1964 and possibly about 9 H.P. Unfortunately it has sat, partially covered in the weather for some time and due to this, I found it necessary to remove the flywheel. I did this to clean it and the associated components of the ignition system. Having done that, I attempted to replace the flywheel when I realized it has no keyway. The crankshaft does have a small keyway but the flywheel has none. It is a tappered shaft and I am concerned as to how the engine is timed! Would anyone be able to offer advice re this situation as I have not been able to find any workshop manual pertaining to this old engine. Would be most grateful for any suggestions. Thank you.
The Following User Says Thank You to Shamus1 For This Post:
Old 06-17-2018, 11:31:19 PM
Default Re: Help
A model 23A does need a key to time it. The flywheel does not have magnets. The magnets are on the rotor that is keyed to the crankshaft to time it. Some later model 23 engines are keyed to the flywheel because they use a different magneto type. Someone here can probably steer you to some Briggs PDF files so you can see the different models of model 23 engines.
---------- Post added at 11:31:19 PM ---------- Previous post was at 11:28:24 PM ----------
Oh yeah, welcome to SmokStak.
Old 06-17-2018, 11:31:59 PM
Default Re: Help
My guess is keys are there, but that the key has sheared off flush with both surfaces.
Once found and removed a new key will be needed.
Oh... my ignorance.
Doc
The sound of one hand clapping is... Whoosh.
Old 06-17-2018, 11:33:09 PM
Default Re: Help
That is does not need a key to time it. Sorry.
Old 06-17-2018, 11:44:25 PM
gdstew gdstew is offline
Default Re: Help
hope this helps
https://www.briggsandstratton.com/co...0-domestic.pdf
Old 06-18-2018, 10:59:35 PM
s100 s100 is offline
Default Re: Help With Briggs and Stratton
Welcome Shamus 1. Evil Dr is correct, the flywheel is not keyed to the crankshaft. The magneto rotor is located behind the flywheel (closer to the engine block) and it is best to not remove it if you don't have to as timing it is a bit fussy. Actually not fussy but hard to explain here. The maintenance manual provided by gdstew does not cover this topic. But if it is already off fear not we will get you going.
These old cast iron Briggs are extremely fine engines and will run forever with a bit of maintenance. They are very much worthwhile projects to get going again.
The Following User Says Thank You to s100 For This Post:
Briggs & Stratton 23 Nick Lingg Small Air Cooled Gasoline Engines 2 04-30-2013 08:23:40 PM
FH Briggs & Stratton. Lester Bowman Small Air Cooled Gasoline Engines 16 05-26-2012 10:20:34 PM
Briggs & Stratton What have I got? steve hales Small Air Cooled Gasoline Engines 10 04-16-2012 11:10:59 PM
Briggs & Stratton Jerry B Small Air Cooled Gasoline Engines 1 08-10-2009 10:41:02 PM
Briggs and Stratton ID Outlaw Small Air Cooled Gasoline Engines 8 08-02-2009 09:47:58 PM
