Recharging Magnets on FH Briggs
this thread has 2 replies and has been viewed 386 times
Old 06-22-2018, 10:12:31 AM
mag473 mag473 is offline
Default Recharging Magnets on FH Briggs
Advice needed to recharge magnets on the flywheel of an FH Briggs and Stratton gas engine. A friend has a charging device that used on various magnetos, but is not configured to charge flywheel magnets. Thanks
Old 06-22-2018, 12:55:40 PM
Exclamation Re: Recharging magnets on FH Briggs
You need to get the proper pole pieces in order to charge the magnets. They will fit inside the flywheel and make contact with the magnets. You will have to note polarity. If you reverse it, the magnets will discharge rapidly. Your best bet is to contact a good mag shop and have them recharge it for you. No guesswork, and they have the strong chargers to do the job right. there are several sponsors here on the Stak, that do mag work and re-charge magnets.
Old 06-22-2018, 03:42:10 PM
Trevor Alder Trevor Alder is offline
Default Re: Recharging Magnets on FH Briggs
Heres a guide for recharging flywheel magnets in the letter series Briggs:
http://www.oldengine.org/members/mur...t_charging.htm
Gladly pay to get my Briggs Z magnets charged. Jack H Magnetos, Ignition Coils and Spark Plugs 3 07-19-2017 12:57:34 AM
1929 Briggs - How do you recharge flywheels magnets chade1968 Antique Gas Engine Discussion 1 07-24-2012 07:14:28 PM
Briggs Model Y Flywheel Magnets BigGoomba Small Air Cooled Gasoline Engines 2 08-31-2011 10:36:30 PM
Recharging Magnets in Wico EK Hal Davis Magnetos, Ignition Coils and Spark Plugs 7 10-03-2009 12:56:41 PM
Recharging Magnets (Maytag) Steve B Maytag Engine Collectibles 5 08-09-2007 11:33:54 PM
