Welding Shop
Miller 200LE overcharging and fuel issue
this thread has 3 replies and has been viewed 1649 times
Old 10-13-2014, 08:29:54 PM
mooseracing mooseracing is offline
Default Miller 200LE overcharging and fuel issue
Picked up one up from an auction for a decent price to use as a welder and backup gen.
It ran and had good oil pressure, but shortly after playing with it, the fuel pump started to have an issue and the oil smelled like gas. Just recently picked up a rebuild kit from Onanparts. After "rebuilding" the pump, I can't seem to get it to run good. I would almost say it isn't getting enough fuel. I say this because first starting after sitting it will run for a little and be able to accel. Then it seems like after it is warmed up it will die off of idle. I can use the choke which will keep it running but not get the full rpm when opening the throttle, also not really any black smoke when using the choke like I would expect.
Issue 2, if adjusting the idle down to 89-90 volts, at power rpm (when it wants to run), I am getting 140 volts. What else can be adjusted here?
IIRC, it was a '74 spec CCKA. I have rebuilt the fuel pump and put in new NGK plugs equivalent to Champion H10's.
Old 10-16-2014, 09:05:49 PM
ttyR2 ttyR2 is offline
Default Re: Miller 200LE overcharging and fuel issue
If you disconnect the fuel line from the carb and put it in a container and crank the engine over, do you get a healthy flow of fuel coming out? If not, the pump is still screwed up.
Old 10-20-2014, 09:55:57 AM
My inherent problem is I second guess my results too much if they don't match a specific measurement for a a test. With that healthy flow doesn't give me a specific amount to measure, so I will always wonder if mine is flowing enough even though when I look at it, it sure looks that way.
Anyway, cleaned the passage ways int he carb again, because it sure looked by manually priming the pump that it would have plenty of fuel to run. Also the carb had fuel in the bowl.
After that it seemed to run decent. I'm going to throw a filter on it as I could see crap in the sediment bowl moving around when manually priming and I wonder if something made it that way.
Onto the voltage battle.
Old 10-28-2014, 11:04:11 AM
wannab1 wannab1 is offline
Try this website for your manual. Someone on another forum gave it to me and my exact welder was here. Helped a BUNCH.
I don't use a fuel pump...gravity flow works great!
http://www.millerwelds.com/service/l...&submit=Search
---------- Post added at 11:04 AM ---------- Previous post was at 10:34 AM ----------
I have a Onan Engine Manual if you need it. PM me.
miller aead 200le marvgarr Welding Shop 2 08-23-2013 01:47:58 PM
TIG set up for my Miller AEAD 200LE? cweaver7018 Welding Shop 2 11-13-2010 10:22:45 PM
Miller AEAD-200LE welder-generator Lil Joe Welding Shop 2 10-17-2010 01:35:22 AM
Miller Blue star 2E OR AEAD 200LE bobgil Welding Shop 3 05-12-2010 09:31:48 PM
Miller AEAD-200LE: Engine options ASavage Onan Generators 6 11-15-2006 12:05:41 AM
