Welding Shop
Lincoln Electrics , 400AS-50 Welding Machine .
this thread has 2 replies and has been viewed 3904 times
Old 03-10-2014, 06:14:52 AM
Watkins Katu Watkins Katu is offline
Location: Port Moresby , National Capital District , Papua, New Guinea
Thumbs up Lincoln Electrics , 400AS-50 Welding Machine .
I'm working on a Lincoln 400as-50 welding machine . It has no ac output . I changed the brushes , both ac and welding brushes and changed both capacitors . Made a continuty test on all the windings , tested the rectifier pack which all seem to be ok . The engine side as no problems . Is there anything else I need to do or haven't done to get the desired output ? Please I realy need your help cause we have only this machine , that is now in great need . Thankyou in advance and am looking forward for your favourable response . Sincerely Watkins
Old 03-11-2014, 10:47:24 PM
motormanjeff motormanjeff is offline
Default Re: Lincoln Electrics , 400AS-50 Welding Machine .
I've not worked on this particular one, but on my 'Lincoln Classic II" which has a DC generator with an AC exciter that is rectified to excite the generator. Once I started it by applying power to the welding leads(which I've done many times with these lincolns) but we had the polatity wrong. after that I had no power anywhere. no 110ac, no welding current, nothing anywhere. to fix it I had to "flash the fields". To do this I put jumper leads on the 12volt starting battery and touched the exciter brushes. this is a very simple procedure, but it took me a week to figure out this was all that I needed. According to the lincoln book this is supposed to be done with the engine off. I tried twice and still had nothing, being frustrated after the second time and a week of testing diodes and such, so I still had the thing running and thought what the heck, I touched the brush connections with my jumpers and it arced and like magic I had 124volts at my ac plug and about 102 ocv at the welding leads It's worked great ever since. I've seen the machines with the dc exciter get the polarity turned around. To fix this you just "flash the fields" to correct it
The Following User Says Thank You to motormanjeff For This Post:
Old 03-23-2014, 06:26:46 PM
Brian Howard Brian Howard is offline
Scribd has a manual that has some good troubleshooting tips.
http://www.scribd.com/doc/94822072/400AS-50
Miller SRH-333/Hanovia 3 Phase to Single Phase Conversion dalmatiangirl61 Welding Shop 64 08-24-2019 11:23:07 PM
Lincoln Electrics , 400AS-50 Welding Machine . Watkins Katu Welding Shop 0 03-10-2014 06:07:57 AM
Help with an old welding machine! anakell Welding Shop 7 10-01-2012 09:24:40 AM
Lincoln SA 200 not welding cocomunk Welding Shop 10 12-22-2010 08:41:40 PM
Smith Welding Machine DannyP Welding Shop 3 11-19-2007 11:30:39 PM
