Welding Shop
oxy-acetylene torch troubles, burning in mixer, popping
this thread has 23 replies and has been viewed 10993 times
Old 04-24-2014, 11:57:04 AM
Default Re: oxy-acetylene torch troubles, burning in mixer, popping
I bought some flame arresters, they are designed to prevent flash back explosion fires. I have decided to place them on the tanks.
I always leave the door open, and the torch is no longer leaking.
I always weld outdoors on concrete. I tend to also leave the torch outside till everything is cool.
I always turn off the tank valves. It is a list I follow in my head. I even go back and check after finishing up.
I do not use the torch as an everyday normal working thing, so I am more aware of being careful with it.
So I am not concerned, I have a working technology and personal habits that aids me, helps prevent my idiocy. I do have my idiotic moments.
Old 04-27-2014, 09:05:35 AM
Got them and they look real nicely made, heavy.
These do have a check valve, they only flow one way.
Old 04-27-2014, 09:27:33 AM
Tony Rye Tony Rye is offline
turning up the pressure passed what is needed hides the problem get a chart that tell you what pressure is needed to cut the matl. you are cutting and see what is does . the barrel can blow up . there are servale thinks that can cause this a lot of time it is the seat of the tip are the seat in the head it is a machine fit no seals
Old 04-27-2014, 12:10:41 PM
I had the oxygen set too low for the big tip.
It was on 50 kpa which is 7psi, too low.
Not enough oxygen pressure it burns in the torch.
that setting was working fine for the much smaller pencil tips.
---------- Post added at 12:10 PM ---------- Previous post was at 11:47 AM ----------
Good vid on lighting the torch and using the valves.
https://www.youtube.com/watch?v=OReU...eature=related
setting up regulators and PSI
https://www.youtube.com/watch?v=RLwH...eature=related
doing some welding
https://www.youtube.com/watch?v=y2Zx...eature=related
This guy is fun to watch
https://www.youtube.com/watch?v=3ZFnaP9QJ6k
He lights the torch with oxy slightly on, which I also do sometimes.
https://www.youtube.com/watch?v=i0IC...otation_685778
The Following User Says Thank You to sdowney717 For This Post:
Popping sound Twin34 Generators & Electric Motors General Discussion 4 04-05-2013 02:47:57 PM
Propane tip for old oxy/acetylene cutting torch PTSideshow Welding Shop 9 06-26-2011 02:55:49 PM
Another 2 cylinder popping 4myJD630 Antique Farm Tractors 2 06-24-2008 05:12:49 AM
Need help with acetylene torch Ronald E. McClellan Welding Shop 9 03-16-2007 09:13:17 PM
