Welding Shop
cast iron head repair
this thread has 4 replies and has been viewed 2535 times
Old 07-27-2014, 04:07:18 PM
Jerry Widener Jerry Widener is offline
Default cast iron head repair
I have a 6 hp international m engine with a busted head. What is the best way to patch a cast iron head with a missing piece ? cast or metal? brass or stick weld? Thanks in advance
Old 07-27-2014, 05:34:27 PM
joneg joneg is offline
Default Re: cast iron head repair
hello
i would recommend you avoid stick welding, especially if its a water jacket area. i would use an acetylene torch with cast iron rod, or a powder spray torch if available, or braze it with brass
jon
The Following User Says Thank You to joneg For This Post:
Old 07-27-2014, 11:06:48 PM
IronworkerFXR IronworkerFXR is offline
how about a picture so we can evaluate it better .
like everything read the forum here for info , I depending on it would use palco 808 cast iron rod with a stick welder pre and post heat stress re-leaf with my needle scalier . thats ME .
The Following User Says Thank You to IronworkerFXR For This Post:
Old 07-28-2014, 07:35:39 AM
ShaneZahn ShaneZahn is offline
I read the following post over the weekend. Very interesting.
Check it out, for ideas.
http://www.smokstak.com/forum/showthread.php?t=113626
Shane
The Following User Says Thank You to ShaneZahn For This Post:
Old 07-28-2014, 10:12:17 PM
Don't weld it, Lock N Stitch.
http://www.locknstitch.com/
Cast Iron repair Maytag.Fixer Hit & Miss Gas Engine Discussion 21 12-08-2013 02:26:54 PM
Cast Iron crack repair GlennW Hit & Miss Gas Engine Discussion 8 11-12-2010 03:00:39 AM
Need some cast iron repair help... George Andreasen Hit & Miss Gas Engine Discussion 1 11-23-2009 04:04:14 PM
Epoxy to repair cast iron??? JKWidener Hit & Miss Gas Engine Discussion 14 05-18-2007 09:39:04 AM
Cast Iron Crack Repair Mike Inglis Hit & Miss Gas Engine Discussion 13 01-19-2005 04:22:52 PM
