Welding Shop
Wisconsin TFD Welder
this thread has 2 replies and has been viewed 1743 times
Old 09-17-2014, 07:16:26 PM
poolman88 poolman88 is offline
Default Wisconsin TFD Welder
I found a 1956 Wisconsin TFD two cylinder with a Lincoln arch welder. After a lot of work i got her running .Just curious what something like this is worth
Old 09-17-2014, 11:27:22 PM
dkamp dkamp is offline
eMail NOT Working
Default Re: Wisconsin TFD Welder
If you can get it to generate a good strong, stable arc, and have the discipline to properly clean, fit, and chamfer the metal, select the proper rod, and maintain a steady hand while drawing the bead... somewhere between $65-$90 per hour depending upon the local labor market demands. You'll find it's worth more in the higher range when you can do good-quality overhead and vertical beads... and even more if you have it in the back of a truck and can respond to phone calls within a half-hour...
Old 09-17-2014, 11:41:50 PM
John Newman, Jr.'s Avatar
There is a guy in my neighborhood that runs an auto repair shop who has one of these. He had it in the back of a truck for a while and now it is on the floor of his shop with a bunch of other stuff. Looks like he wheels & deals quite a bit, so it is probably for sale. It looks to be all there. What would be a typical value on one of these? I'd consider making an offer on it if I thought I could get it at a reasonable price (cheap would be better )
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Wisconsin Engine, Hobart Welder moparguy Magnetos, Ignition Coils and Spark Plugs 1 05-17-2012 06:10:01 PM
Wisconsin TF powering a Hobart welder. Brisco YouTube Old Iron Videos 1 01-29-2011 02:58:10 PM
My Hobart Welder with Wisconsin TF Brisco YouTube Old Iron Videos 0 08-21-2010 12:59:17 PM
Old Hobart gas driven welder with 2 cyl Wisconsin Howie Marion Welding Shop 8 11-12-2009 09:01:35 PM
Hobart G-213 Welder and Wisconsin TJD bugle Welding Shop 4 09-15-2009 06:44:57 PM
