Welding Shop
SA-200 polarity
this thread has 2 replies and has been viewed 1786 times
Old 11-18-2014, 12:19:29 PM
Azcopper Azcopper is offline
Default SA-200 polarity
I have a 1955 SA-200 that sat for about 10 years when i got it running the polarity was reversed so i flashed the field and corrected it and went to use it a couple days later and it was reversed again. It welds good and the auxiliary plug has good voltage. Any
Old 11-18-2014, 10:02:38 PM
motormanjeff motormanjeff is offline
Default Re: SA-200 polarity
I know a pipeliner who had a 1970 sa200 that switched polarity. he just swapped the leads and used it for 4 or 5 months before he flashed the fields and corrected it. I don't think it hurts anything to use it that way but I would think it should stay once you fixed it. I would try again and do some pretty heavy welding with it. Maybe it will stay this time.
Jeff
Old 11-18-2014, 10:51:44 PM
Ok I will try that I wonder what causes it to reverse polarity the lack of magnetism.thanks
battery polarity cooter 1954 Onan Generators 6 09-01-2011 08:32:52 PM
Wico EK Polarity? Jon Mrozinski Magnetos, Ignition Coils and Spark Plugs 8 01-08-2011 10:14:42 PM
Changing polarity flasks Generators & Electric Motors General Discussion 2 01-20-2009 02:58:16 PM
Polarity reverse George Vaughan Magnetos, Ignition Coils and Spark Plugs 4 07-10-2008 10:07:35 PM
Magnet polarity DippyNo12 Hit & Miss Gas Engine Discussion 4 01-10-2007 12:47:10 PM
