Welding Shop
Weldan power g8000
this thread has 2 replies and has been viewed 2239 times
Old 12-01-2014, 07:39:10 AM
tnfarmer67 tnfarmer67 is offline
Default Weldan power g8000
I have a lincoln weldanpower g8000 the problem I'm having is that it does not charge the battery and also if it sits for over a week something drains the battery . It has the 16 hp onan engine that runs great . Any help would be appreciated !
Old 12-01-2014, 07:21:44 PM
John in Maryland's Avatar
John in Maryland John in Maryland is offline
Default Re: Weldan power g8000
Not sure what could be draining the battery. As I recall there are no relays that could stick, everything's electronic. I have a G8000 also. A few years ago I lost all weld and aux power output. I found a burnt spade connector on one of the bridge rectifiers. Replaced it and all was well. I assume you can manually charge the battery and start the unit. Do you have aux and weld power? I'd check all the connections on the circuit board(s) make sure nothing's loose, broken, burnt etc. Here's a couple of links that may help as well.
http://www.lincolnelectric.com/en-us...r-manuals.aspx
http://billswelderrepair.com/SA200schematics.html
http://www.weldmart.com/technical/EX...BLSHOOTING.htm
Keep us posted
J.I.M.
Old 12-01-2014, 08:06:51 PM
Yes I can boost it off to start it and yes I have welding and aux. power . I just printed off the manuals so maybe I can troubleshoot it .
G.M. Power I-4632 no power output Josephbookshed Generators & Electric Motors General Discussion 7 07-28-2014 10:09:38 PM
HELP! IH Cub Power Take Off Jim Tremble Antique Farm Tractors 2 06-26-2013 05:09:09 PM
Engines wanted to power shingle mill at Coolspring Power Museum Chris Austin Coolspring Pennsylvania 0 06-08-2010 09:58:38 PM
Does a Dodge Power Ram 150 have towing power? Travis Trucks, Trailers and Hauling for Shows 11 02-07-2009 09:39:46 PM
Power out walt Generators & Electric Motors General Discussion 1 09-27-2004 02:56:41 AM
